Hi guys
Yet another problem, and one I've been having for some years (read, earlier releases as well). I finally got around to test the behaviour of the problem and came to a conclusion.
After using trim twice in the same end of a Frame Generator part, G_L stops updating.
Is there any known workaround?
This was the only thing I found from Autodesk in regards to the problem.
Also, 2017.3 doesn't fix it. I found a topic stating that it should fix some problems in regards to the Frame Generator.
I found some workarounds back from 2011 and 2012, but they don't seem to work anymore.
Best regards
Yannick
Is there anything official stated about this?
Verified in Inventor 2017.3
After the first trim operation, G_L shows the shortened length of the frame member. After applying a second trim operation, G_L reverts to the original value of the un-trimmed member.
@YannickEnrico I was able to make this work, however, by applying one trim, and then a notch for the second cut. My geometry is slightly different from yours, but maybe try this and see if it works on yours?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for the suggestion.
I have never gotten Notch to update G_L.. Not in this version, nor through versions through 2012-2016.
I just attempted again in 2017.3, and the issue is the same. Notch doesn't update it - Doesn't matter whether I used a trim or not.
And two x trim still only updates on the first one, not the second one.
Did you do the notch AFTER a trim, before, or by itself?
My experience has always been that a notch works best when used AFTER a trim... otherwise I see what you are seeing, G_L doesn't work.
Chris Benner
For testing purposes, I tried the following work flows:
Trim -> Notch
Notch
Notch -> Notch
Notch -> Trim
Only the ones including a trim changed G_L, because Notch didn't in any workflow change G_L.
However, both the first and last still output the wrong length
Just wanted to comment on your statement.. Notch is considered a fit to the job. It will never update the G_L value. Meaning in the manufacturing process, the member would be cut to a desired length (so you would trim your member to a certain point pass the notch) and then the person or persons performing the construction would grind the structure to the desired shape profile..
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Mark.Lancaster I think I've been told that before, but somehow forgotten.
That explains why I can't get it to work. Doesn't explain how @cbenner seems to get it to work, though 😄
I should clarify that what I end up with doing: Trim > Notch, is the cut length of the trim. The notch does not modify G_L, just like @Mark.Lancaster said. I wasn't clear on this, sorry. The cut length comes form the trim, and our steel guy knows to grind the notch FROM the cut length.
Chris Benner
@cbenner - Ah, that does indeed make sense.
Thinking about it, I suppose it makes sense to some degree that it only creates cut length for one trim, because usually you would cut it at an angle.
Outputting the dimension I want, means you'll lack profiles unless you make three cuts rather than two....
