Inventor Forum
Inventor 2017 Frame Generator Issues with two x trim
9 REPLIES 9
Message 1 of 10
YannickEnrico
577 Views, 9 Replies
YannickEnrico
Hi guys
Yet another problem, and one I've been having for some years (read, earlier releases as well). I finally got around to test the behaviour of the problem and came to a conclusion.
After using trim twice in the same end of a Frame Generator part, G_L stops updating.
Is there any known workaround?
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
This was the only thing I found from Autodesk in regards to the problem.
Also, 2017.3 doesn't fix it. I found a topic stating that it should fix some problems in regards to the Frame Generator.
I found some workarounds back from 2011 and 2012, but they don't seem to work anymore.
Best regards
Yannick
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2024 Professional
Hi guys
Best regards
Yannick
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
9 REPLIES 9
Message 2 of 10
YannickEnrico
Is there anything official stated about this?
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 3 of 10
cbenner
in reply to: YannickEnrico
cbenner
Verified in Inventor 2017.3
After the first trim operation, G_L shows the shortened length of the frame member.  After applying a second trim operation, G_L reverts to the original value of the un-trimmed member.
@YannickEnrico  I was able to make this work, however, by applying one trim, and then a notch for the second cut.  My geometry is slightly different from yours, but maybe try this and see if it works on yours?
Message 4 of 10
YannickEnrico
in reply to: cbenner
YannickEnrico
Thanks for the suggestion.
I have never gotten Notch to update G_L.. Not in this version, nor through versions through 2012-2016.
I just attempted again in 2017.3, and the issue is the same. Notch doesn't update it - Doesn't matter whether I used a trim or not.
And two x trim still only updates on the first one, not the second one.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 5 of 10
cbenner
cbenner
Did you do the notch AFTER a trim, before, or by itself?
My experience has always been that a notch works best when used AFTER a trim... otherwise I see what you are seeing, G_L doesn't work.
Message 6 of 10
YannickEnrico
YannickEnrico
For testing purposes, I tried the following work flows:
Trim -> Notch
Notch
Notch -> Notch
Notch -> Trim
Only the ones including a trim changed G_L, because Notch didn't in any workflow change G_L.
However, both the first and last still output the wrong length
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Trim -> Notch
Notch
Notch -> Notch
Notch -> Trim
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 7 of 10
Mark.Lancaster
Just wanted to comment on your statement..  Notch is considered a fit to the job. It will never update the G_L value.  Meaning in the manufacturing process, the member would be cut to a desired length (so you would trim your member to a certain point pass the notch) and then the person or persons performing the construction would grind the structure to the desired shape profile..
Mark Lancaster
Mark Lancaster
Message 8 of 10
YannickEnrico
@Mark.Lancaster I think I've been told that before, but somehow forgotten.
That explains why I can't get it to work. Doesn't explain how @cbenner seems to get it to work, though 😄
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 9 of 10
cbenner
cbenner
I should clarify that what I end up with doing: Trim > Notch, is the cut length of the trim.  The notch does not modify G_L, just like @Mark.Lancaster said.  I wasn't clear on this, sorry.  The cut length comes form the trim, and our steel guy knows to grind the notch FROM the cut length.
Message 10 of 10
YannickEnrico
YannickEnrico
@cbenner - Ah, that does indeed make sense.
Thinking about it, I suppose it makes sense to some degree that it only creates cut length for one trim, because usually you would cut it at an angle.
Outputting the dimension I want, means you'll lack profiles unless you make three cuts rather than two....
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
