Inventor Forum
Inventor 2017 Drawing Missing Line In Section Part Doesn't Show
5 REPLIES 5
417 Views, 5 Replies
Hi, lately I had some problems with section in drawing
some part don't show even if they're set up for section participation
weird thing is when I activate the shaded option I see the part but there's no line for the contour
so when I turn the shaded off the part doesn't show no more..
someone else had this issue, I use inventor 2017
kelly.young has edited your subject line for clarity: Missing line in section
5 REPLIES 5
TheCADWhisperer
Have you installed all Updates?
Can you attach files (or at least image) that illustrates this behavior?
Can  you reproduce the behavior with other files?
johnsonshiue
Hi! The behavior sounds geometry specific. If possible, please share the files here so forum experts can comment further.
Many thanks!
Software Test Engineer
in reply to: johnsonshiue
ould share file but it's too big..
weird things is when I do a detail the part show on the details but not on the section...
I've installed all the update and the problem still there
kelly.young
@Anonymous without the part, an image showing the behavior, or a screencast of your workflow we are having to guess what might be happening.
Is the part that you are sectioning normal to the plane view? Meaning if it is slightly askew it can give odd results from sections.
Are there view representations that are being shown in the section rather than the master view?
A bit more information would help identifying the issue. Thanks!
Please select the Accept as Solution button if a post solves your issue or answers your question.
kelly.young
@Anonymous were you able to get your section figured out?
If you RMB the part in the browser and change Section Participation to on
