Inventor 2016, Some local lights won't turn on, lights limit
I hope that out there there is somebody that can help with an odd probplem I'm having with autodesk local lighting.
I need to create a linear light, a LED bar, that illuminates some objects.
I have created a bar of Luminous material, like explained in this post
However Inventor does not allow to modify and resize the dimension of a light giving it a rectangular shape, so I decided to insert many local light points inside the luminuous bar to to have more light to finally achieve the LED bar linear effect.
I started copying and paste the lights and only 8 lights are swithed on, if I insert more light points  they don't render, anybody knows how to fix this bug
I have seen somebody else had the same problem
I have attached an image that clearly shows the issue
mcgyvr
It might be a "limitation"..
I found other posts (not specifically about autodesk) stating an 8 light limitation from the OpenGL days...
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/OpenGL-8-Lights-per-obje...
Daniel248
