Inventor 2016, Some local lights won't turn on, lights limit
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I hope that out there there is somebody that can help with an odd probplem I'm having with autodesk local lighting.
I need to create a linear light, a LED bar, that illuminates some objects.
I have created a bar of Luminous material, like explained in this post
However Inventor does not allow to modify and resize the dimension of a light giving it a rectangular shape, so I decided to insert many local light points inside the luminuous bar to to have more light to finally achieve the LED bar linear effect.
I started copying and paste the lights and only 8 lights are swithed on, if I insert more light points they don't render, anybody knows how to fix this bug
I have seen somebody else had the same problem
I have attached an image that clearly shows the issue
