08:17 AM
Hello all,
I recently upgraded to 2016 and I've been working with sheet metal parts. The past 2 projects I've worked on, when I try to create a flat pattern. The flat pattern is crooked. I've tried changing 'define A side', deleting and recreating. Even when I place it into a drawing it comes into the draiwng crooked. I end up rotating it on the angle it's crooked on. I've had 2 different part files do this and both time is was a different angle. Please help!
Thank you.
Ashlee
Link copied
