Inventor 2016 Download Software Setup Error Install Message
Message 1 of 14
Hi, I need to download this software to finish some of my parts for engineering class but I keep getting an error. Any help is appreciated. Here is the error message
https://gyazo.com/eb0bdaf66950af685d2c22ff19fa2512
I'm using the three part download thing.
kelly.young has edited your subject line for clarity: URGENT NEED HELP FAST
Replies (13)
Message 2 of 14
johnsonshiue
Hi! Cancel Inventor install. Go to All Programs -> Autodesk -> Autodesk Uninstall Tool -> uninstall Inventor 2016 related items. Then go to File Explorer -> %temp% -> delete most of the files there. After that, retry the install.
Many thanks!
Software Test Engineer
Message 3 of 14
Will I have to redownload it
Message 4 of 14
johnsonshiue
Hi! I am not sure. I don't know if the failure is due to incomplete download or other install failures. At this point, I don't see a need to download it again. Please follow my instruction and see if it works for you.
Many thanks!
Message 5 of 14
It told me that it couldn't start automatically and to start it manually but I have no idea how. There is no icon anywhere.
Message 6 of 14
Still isn't working for some reason, getting the same error. Guess I'm settling for an F
Message 7 of 14
rhasell
Hi
Did you do a Browser download?
If not, then re-download your software, and re-install it as mentioned by Johnson.
Reg
2026.1
Message 8 of 14
TheCADWhisperer
You should first download these three files.
Downloading files is not installing anything. Same as downloading any other three files.
Once you have these three files and posted image to verify - we can proceed with installation instructions.
I assume that your school is using 2016 from your image.
Message 9 of 14
Frederick_Law
Problem solving is a huge part of Engineering.  So keep trying and don't leave assignments to the last moment.
Well, been there, done that, lesson learn.
Message 10 of 14
Mark.Lancaster
@Anonymous
Also its important that you don't post in mutiple forums (https://forums.autodesk.com/t5/installation-licensing/softlock-lizenz-manager/td-p/7998242)..  Post once and someone will assist you..   Anyhow my reply in the Installatoin and Licensing forum will resolve this issue you're seeing.
Mark Lancaster
Message 11 of 14
mcgyvr
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal...
Just adding this from the knowledgebaseas there is a good workaround there that wasn't discussed here..
Message 12 of 14
mcgyvr
Linkie.. no workie....I get "An invalid set of parameters has been specified in the url." in your link..
Message 13 of 14
Mark.Lancaster
@mcgyvr
Yes it was..  I posted the solution early this morning...   Where have you been?  Smiley LOL
Oops..  I missed that you posted my URL wasn't working..  Shame one me..
Mark Lancaster
Message 14 of 14
mcgyvr
I don't see where you post that link in this thread???
The only posts from you are #10 (bad link) and #13..
edit: glad you noticed your link was broken now.. Smiley Tongue
