Inventor Forum
Inventor 2016 crashing at launch
25 REPLIES 25
Message 1 of 26
1302 Views, 25 Replies
Recently I have installed Autodesk Inventor, but the program is unusable. When I start the program the loading screen appears briefly with the loading bar roughly a quarter of the way before crashing, opening an error report that says 'A software problem has caused Autodesk Inventor to close unexpectedly."
I have tried
     - Uninstalling and reinstalling
     - Repairing
     - Updating the program
     - Restarting
     - Running as administrator
I have also had the same issue with the 2017 edition. Other Autodesk programs such as ReCap and a couple other I opened to test appear to work correctly.
Any help, solutions or suggestions would be helpful and welcome.
Cheers,
Jason
25 REPLIES 25
Message 2 of 26
salariua
If you used Download Now or Install Now from your browser then I suggest you clean up and use the offline installer from virtual agent
Here's how to do that.
Then I would use Microsoft FixIt to clean up the old installation, may resource for this.
https://knowledge.autodesk.com/customer-service/download-install/remove-products/remove-windows-prod...
https://knowledge.autodesk.com/customer-service/download-install/remove-products/using-microsoft-fix...
Make sure you disable UAC (user account control in control panel) and any security software that could block the installation.
If it fails once again to install or run properly then install AIDA (Autodesk® Installation Diagnostic Assistant) and send us the reports it generates.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 26
in reply to: salariua
I have tries all the steps you asked but am still experiencing the same problem unfortunately. I have attached the AIDA zip file (I think I scanned the correct folder) so if you know anything else that could help from that it would be much appreciated.
Also, during both installation and uninstalling the error report appeared again while the inventor program of the Autodesk package was being installed/uninstalled, if this information is of any significance.
Cheers
Jason
Message 4 of 26
salariua
Do you have a screenshot? an error message or error code?
you do have an "error 1603" but that's during Configurator 360.
If you used MIcrosoft FixIt I would suggest you try it again and again till the product is no longer showing (it might take more than one attempt).
Make sure you have administrative rights, and that UAC is off.
I will ask @ChrisMitchell01 to take a look at it and see if anything else surfaces.
Try to install again and apply the updates as well, with full restarts in between.
if that fails again then try to create a new user account (administrator) and try from there.
Adrian S.
blog.ads-sol.com
Message 5 of 26
After the program crashes, this error report is all that comes up.
Jason
Message 6 of 26
salariua
Send me a private message with the files in your error message along with a system info.
DO NOT post those open on the forum, there is sensitive info there.
Adrian S.
blog.ads-sol.com
Message 7 of 26
I am unable to add attachments in a private message (or cant figure out how to), is there another way that I can send you my system info and the files?
Jason
Message 8 of 26
salariua
Upload it to my Dropbox here.
Adrian S.
blog.ads-sol.com
Message 9 of 26
I have uploaded the files.
Message 10 of 26
salariua
Can you change "FLEXnet Licensing Service 64" to automatic, please? it's on manual and stopped now.
  1. Access the Windows Run box.
  2. Type Services.msc and press Enter.
  3. Search for FLEXnet Licensing Service 64.
  4. Make sure the services are started and running
Double click on it and change it to Automatic and click on start.
Adrian S.
blog.ads-sol.com
Message 11 of 26
salariua
next would be to disable any add-ins.
navigate to "C:\Program Files\Autodesk\Inventor 2017\Bin" and run "AddInMgr.exe" disable all add-ins and try again.
Adrian S.
blog.ads-sol.com
Message 12 of 26
When attempting to run 'AddInMgr.exe', an error message reading 'The current version of Inventor is not currently registered and did not correctly re-register on star up.' appears. is there another option/way to solve this?
Message 13 of 26
salariua
searched some more on your problem and you seem to have error "0xE0434352" just like here.
Adrian S.
blog.ads-sol.com
Message 14 of 26
I have tries repairing and updating windows. It is all up to date except for one security update that repeatedly fails (KB4025339), but when I try to manually download this, a message appears claiming that the update isn't applicable for my computer.
Message 15 of 26
salariua
I would try and install all Inventor updates. Maybe one of those will override just the right files and make it work.
Adrian S.
blog.ads-sol.com
Message 16 of 26
Mark.Lancaster
@Anonymous
Were you able to resolve your issue based on @salariua info?
If you are still getting the crash (reports). private message me and I will inform you of your next step.
Mark Lancaster
Message 17 of 26
salariua
in reply to: Mark.Lancaster
Hi @Mark.Lancaster, thanks for joining in.
if @Anonymous agrees I can share the Dropbox files with you.
Adrian S.
blog.ads-sol.com
Message 18 of 26
Yeah you can send the dropbox files. Also thank you for attempting to help me.
Cheers,
Jason
Message 19 of 26
Mark.Lancaster
@Anonymous
There's nothing else I can really add to this since @salariua has already pointed out what the error is stating in the crash report that you sent.
Have you tried creating another user on your machine and see if the crash report still appears when you launch Inventor?
If you look at the Windows Event logs on your machine at the time when you launch Inventor are you seeing any warnings or errors there?
Do you have netframe 4.7 installed?
Mark Lancaster
Message 20 of 26
salariua
@Mark.Lancaster wrote:
@Anonymous
One thing I didn't hear from @Anonymous if he started the FlexNet Service and changed it to automatic.
Adrian S.
blog.ads-sol.com
Technology Administrators
