Inventor 2015 Thread error - "Unable to successfully update the member part..."
Message 1 of 11
Since last week we are experiencing a problem with Inventor 2015 when trying to make threaded holes or import bolts, nuts, ... from within the Content Center.
When trying to import from Content Center following error appears:
"Unable to successfully update the member part file. Problem occurred when setting the thread data."
I have tried replacing the Thread file with the file stored on my local pc (we are using the Design Data located on server) but this does not solve the problem. Our Thread.xls file is attached if necessary.
One colleague using Inventor 2016 is not experiencing any problems.
Does anybody know how to solve this problem?
Thank you very much,
Willem
Replies (10)
Message 2 of 11
Vadim-the-Engineer
Message 3 of 11
Mark.Lancaster
Recent Windows updates has caused this issue.  Please see this posting for additional information.
Mark Lancaster
Message 4 of 11
Sadly enough this does not work for us.
Message 5 of 11
mdavis22569
What OS are you on?
Mike Davis
Message 6 of 11
mcgyvr
See this.. what vadim posted is not the issue..
This is..
Mark tried to direct you to it but may have gotten to fancy for you and embedded the link in the sentence..
Click here and read this...
https://forums.autodesk.com/t5/inventor-forum/recent-microsoft-security-updates-might-cause-problems...
Message 7 of 11
Uninstalling security update 4041681 helped indeed.
Thank you very much for your help!
Message 8 of 11
Yasinv9998
How can i find 4041681?
Message 9 of 11
kelly.young
Autodesk Support
Autodesk Support
Hello @Yasinv9998
I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Here are some screenshots to show where to locate the Update History:
Also a couple of good links that should help explain where to find the updates:
October 10, 2017—KB4041681 (Monthly Rollup)
Software and security updates: Why they’re important and where to find them
Identifying installed updates on Microsoft products
How to Find the List of Windows Updates on My Computer
Always scan for viruses and download from third party websites at your own risk.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 10 of 11
Yasinv9998
Hello
I cant uninstall the security update, How can i do it?
Message 11 of 11
kelly.young
Autodesk Support
Autodesk Support
@Yasinv9998 if you do an Internet search there are good general help articles you can find.
Here is a link that should explain how:
How to uninstall Windows Updates
