- Mute
- Permalink
- Report
Maybe the sketch environment could be a little tidier?
1 - I think by default the constraint icons should be smaller so they don’t pile up on top of each other and you can’t see what they are. They appear to be much neater and easier to read in SW?
2 - In the attached sketch it shows there are 3 dimensions needed even though the lines are now dark blue in color showing they are constrained. They are really not fully constrained because the length of both those lines can be changed.
I think there should be a symbol to show those line end points are not locked down. I have drawn “x” marks on those lines to show that. Maybe that or something else would be enough to quickly show not locked. Sometimes on complex sketches I spend much time searching for lines that don’t have their ends locked to fully constrain the sketch. I often use automatic dimension to find where those naughty lines are but an x on the end would be much faster.
The sketch environment is the basic backbone of the entier program and it needs to be perfect. ![]()
GMT +08:00
