Inventor Forum
Inventor 2014 Wish List?
137 REPLIES 137
Message 1 of 138
FProcp
14919 Views, 137 Replies
Maybe the sketch environment could be a little tidier?
1 - I think by default the constraint icons should be smaller so they don’t pile up on top of each other and you can’t see what they are. They appear to be much neater and easier to read in SW?
2 - In the attached sketch it shows there are 3 dimensions needed even though the lines are now dark blue in color showing they are constrained. They are really not fully constrained because the length of both those lines can be changed.
I think there should be a symbol to show those line end points are not locked down. I have drawn “x” marks on those lines to show that. Maybe that or something else would be enough to quickly show not locked. Sometimes on complex sketches I spend much time searching for lines that don’t have their ends locked to fully constrain the sketch. I often use automatic dimension to find where those naughty lines are but an x on the end would be much faster.
The sketch environment is the basic backbone of the entier program and it needs to be perfect. Smiley Wink
Franco
GMT +08:00
137 REPLIES 137
Message 121 of 138
gavbath
in reply to: dan_inv09
I love new functionality. Frame generator was new functionality once, excellent tool. The productivity enhancement tools were new functionality once, also big time savers. Hey hang on a second, all the tools in Inventor that we all use were new functionality once, and the software has always had bugs (like any software) and yet we still all use it and get the job done. I know that I find ways of increasing my productivity with each new version and some of those improvementas are due to new functionality. Keep putting new functionality in, and if there are problems, I won't use the new tools or find workarounds or new ways of doing things.
People who don't like or can't handle change, can just stick with the old version that they're comfortable with.
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
Message 122 of 138
in reply to: gavbath
I agree. If they hadn't introduced frame generator I would not have been able to use Inventor for my application, it would have been too time consuming. Yes there are bugs, some **** annoying ones, but there is a separate forum for reporting these. Inventor with new functionality and bugs is still faster than no new functionality.
Message 123 of 138
dan_inv09
Change is fine, throwing some junk together and messing up what is already there to say "Look, a new feature!" is bad.
We aren't comfortable with any of the old versions - we keep hoping the next version fixes some of the problems, but they're to busy accommodating people who are too distracted by something shiny to realize everything is falling apart behind them.
What if you had a car, This new model has "turbo boost" except half the time it kicked in the whole car shut down. (Except, instead of being somewhere down the road you end up back in your driveway; you aren't 3/4ths of the way to the doctor's office - you're wherever you saved last.)
"Software always has bugs." How would you feel if Kellogg's felt the same way about your breakfast?
If you could save 5 minutes everyday because of some new functionality, but you still loose 15 minutes a day because of some bugs that have been there for two or three versions ... you think you're ahead, don't you? Because it's new! "Ooh, look, shiny!"
("Two or three versions and you haven't learned to work around it yet?" It's workarounds that keep it to 15!)
"Keep putting new functionality in, and if there are problems, I won't use the new tools or find workarounds or new ways of doing things." That is exactly the point: if you're not going to use it, putting it in was time wasted that could have been used fixing something they added last time that still doesn't work. And if you can find workarounds or new ways of doing things to get around what they screwed up when they added it, why can't you find a new way without them adding broken functionality?
Just because something is different does not make it better.
If it ain't broke ... it's on your to do list, isn't it?
Message 124 of 138
The very same thing I've been asking since Release 5.....when in the world will we finally see "In-Stream modifiers" for dimensioning?
One should be able to select the dimension command and then be prompted with a menu that allows selection of ALL dimensional options such as tolerances, GD&T, pre-foxed text, post text, etc.
These settings stay for all pending dimensions until the user changes them. This allows the user to insert X number of dimensions with the specified tolerance and then be allowed to change the tolerance value for the next few dimensions and so forth...all WITHOUT having to get out of the dimension command.
I understand this selection menu can be somewhat large, but the menu can do the little "roll-up" some menus do now when "pinned". Come on guys, this is such a time saver on the detailing side, how can you not have it done yet?
I've only been requesting this for the past 10 odd releases. I've submitted it on the official request forms and talked to numerous high ranking people on this matter at AU and still, nothing.
If anyone there at ADesk requires more information on this, feel free to contact me directly. That or offer me a job with your company...;)
Message 125 of 138
in reply to: FProcp
Please note to add to the generator SYNCHRONOUS BELTS AND PROFILES Artistic 3M, 5M, 8M and 14m
Message 126 of 138
in reply to: FProcp
I've got a few wishes:
- When creating members trough an assembly "Place from Content Center" it is not possible to create a member longer than 10000 mm (eg. DIN 1025 - IPB). The standard lengths when buying from suppliers in sweden is always 10+ m (12m, 14 m etc.). When creating members trough Frame generator there seems to be no limit in the members length.
- Missing UPE member in contentcenter (DIN 1026-2) parallel flange steel channel. This standard was released in 2002.. That is 11 years ago.
- Missing TORX screws in Content Center!?!? What?
Message 127 of 138
Not just torx screws. Inventor has a very comprehensive library, but no 'Penny' Washers (sometimes called repair washers, mudguard washers or bicycle washers. These are washers with an oversize O/D, used where oversize holes are employed to give a certain amount of movement/adjustment.
I would love the ability to be able to modify existing Content Center parts to create new derivatives like these and add them to Content Center. If there was the ability to publish these to the Autodesk community for others to use, then we could share this content.
The ability to mirror frames and structural members (created in Frame Generator) would be extremely useful. At present if you try to do this, then most of the time you just get a duplicate copy instead of a mirror copy (the same as if you had patterned it). A glitch I'm sure, but one that should be addressed.
Message 128 of 138
SBix26
Please enter your requests in the Inventor IdeaStation forum.  That's currently the official place for such things.  This "2014 Wish List" thread has no official status, so your contributions here may have no affect.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 129 of 138
in reply to: FProcp
I could really use, bolted connections build in to frame generator...
Message 130 of 138
I'd settle for a global setting in application options that allows me to set and leave my Measure Distance Precision Units.
Will AutoDesk ever do this?  Seems like a no-brainer.
Message 131 of 138
in reply to: FProcp
A way to create sectional Positional Representations for overlay in drawing, or a way to section both the master and overlay view at the same time to create a sectional overlay view.
Message 132 of 138
SBix26
These are good ideas, folks, but this thread is not the place to put them (besides which Inventor 2014 is probably less than a month from release, so this has, since the beginning been a 2015 wish list).  Get them into the Inventor IdeaStation forum and post back here to garner support for your idea.
Sam B
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
Message 133 of 138
kstate92
in reply to: SBix26
Sam B
For what its worth: http://forums.autodesk.com/t5/Inventor-IdeaStation/Detail-View-option-to-show-actual-screw-thread-ge...
Though IMHO, this is less likely to happen than me winning the lottery.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 134 of 138
in reply to: FProcp
Automatic drawing files for frame generator frame pieces.
Message 135 of 138
Curtis_Waguespack
Hi Chris,
Have you visited the Inventor IdeaStation yet?
There are several Frame Generator improvement ideas sumbitted there. And this one comes close to what you've suggested:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Add-Model-State-functionality-to-Frame-Generator-...
I would encourage you to take the time to detail out your request in the comments of an IdeaStation idea or by creating a new idea, in order to help the developers better understand you wish request.
I hope this helps.
Curtis
Message 136 of 138
in reply to: FProcp
If I was allowed to dream, and change Preventor to the way it should be.......  Autodesk would rename almost every feature.  Occurrence?  Enable?  Level of Detail?  You have got to be kidding!  How about Position, Transparency and Configuration?  That's what a logical, thining person would name these things.  25% of the incredible frustration that I experience as a Preventor slave is due to the stupidity of the function names - trying to figure out what the Preventor monkey named a functioin is like trying to reason with a drunk.
I would also encourage autodesk to stop setting things up for the 1 in a million user - the person who creates a circular pattern that is NOT 24 instances equally spaced over 360 degrees.  Why in the world do I have to type in 24 AND 15?  15 is implied 99% of the time!  And the 1 percent of the time, it is perfectly acceptable to type in 4 AND 15 - that is expected.
Sketches are truly awful in Preventor - start over.
Constraints are ok, but it is unthinkable that Preventor updates the entire assembly when a part is moved by dragging.  And Preventor does not work properly - you cannot drag a part in its degree of freedom.  This is a serious flaw.
Preventor is also NOT parametric.  I can prove it to you, as Preventor proves it to me every day.  It renames (renumbers) surfaces, which makes everything fall apart.  Modifying a phantom file, when parts are 'grounded' (stupid name - should be 'locked') - and- 'locked' should be the  default - if I 'occurence' a part, I should not be able to drag it.  Back to phantom files - if a part is grounded and positioned, it will FAIL miserable if the phantom file is changed significantly enough.  Shade of gray.
In general, I think Preventor is the absolute worst cad package available, and I would discourage ANYONE from purchasing it.
Edited by
Discussion_Admin
Message 137 of 138
blair
You must have the wrong user forum, this is for Autodesk Inventor.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 138 of 138
And I meant structural detailing by that comment!
