Inventor Forum
Inventor 2013 - Drawing view of part with suppressed features
5 REPLIES 5
501 Views, 5 Replies
Hi, I have created a part created as a flat sheet then folded using the "Bend" command. The problem i have is that I want to represent
the folded version in an assembly and the flat verion in a drawing. I know that  if the part was created in the sheet metal work program then
there are options to achieve this. Is there a way to represent the flat version in the drawing without going back to the part and suppressing
the features. Suppressing the features would then obviously affect  the assembly drawing. This is my first time on the forum.
and would appreciate any help.
Cheers
Mike
Cheers
Mike
5 REPLIES 5
JDMather
JDMather
Bend is not a sheet metal command.
Attach your *.ipt file here and someone will explain how to model it correctly such that you can have Inventor show both the folded and flat patttern in your drawing.
-niels-
-niels-
Welcome to the forum!
From your description it is unclear if you're using Bend in the standard environment or in the sheetmetal environment, so it would be easier if you attach your ipt like JDMather already asked.
If you have a sheetmetal part you can make a flat pattern and put that on your drawing while keeping the formed model in your assemblies.
@JDMather, sheetmetal does have a bend command:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
JDMather
in reply to: -niels-
JDMather
From your description it is unclear if you're using Bend in the standard environment or in the sheetmetal environment, ....
Oops, my mistake.  I was somehow reading Bend Part as the command used.
Cadmanto
Cadmanto
Mike,
Welcome to the forum.
My thoughts are either recreate the part in sheet metal and call it a day, or convert the existing into a sheet metal part to accomplish this.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Mike,
Best Regards,
Scott McFadden
johnsonshiue
johnsonshiue
Hi! Unforunately, the answer is no in your case. Without converting it to a sheet metal part, you could make the part an iPart. One member is in folded state and the other member is unfolded state (Bend Part suppressed) for drawing purpose.
Thanks!
Software Test Engineer
Thanks!
