INV2025 derrived sketchblock behaviour
h_stamP7G6M
h_stamP7G6M
Hi everyone,
i created a part in INV2025 with - only - several sketchblocks.
One of the sketchblocks has several of the other sketchblocks inserted.
when i derrive the sketchblocks in a new part they are not the same as the original. I made originally a square sketch with the two-point center rectangle function. After that i changed the outer line to a construction line and made several offsets.
in the derrive part there is no square shape and a aligned point is way off
i restarted inventor, updated inventor, restarted the workstation and updated the workstation.
I cannot upload the production documents so i made a screenshot and a alternate test version. Sadly enough the blocks are correcty derrived althought the production files are and wont update or display correctly.
What is happening ?
johnsonshiue
Hi! This could be a bug due to mismatched block definition planes. But the files you attached seem to work fine. Regardless, I need to see the problematic files. Please share the files with me directly [email protected]. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
