Interference
Interference
Message 1 of 60
Interference
Interference is detected. I tried to change wing nut to “Major” option but I couldn’t because box is blank, there is no option to select. How to fix it?
Wing nut is placed from content center.
Accepted solutions (3)
Replies (59)
Message 21 of 60
JDMather
I am not in a position to take a decision because I am a novice.
You absolutely must make a decision to pass my class.
Let's frame the question in another way.  We are driving down the road - you are a novice driver and I am the instructor.  A child darts out into the road in front of us. There is not possible for me to instruct you on what to do in the time that a decision must be made.  What is your decision?  (Hint: The correct answer is not, "I am not in a position to take a decision because I am a novice.")
Now make your decision!
No 8, 12 referring to major diameter.
You are just guessing. This is not real answer - I already told you how to present the answer.
When you give your real answer (as opposed to guess answer) also provide the http:// url address to your Reference.
I already told you that you will have to look up the answers in a table - a chart of thread specifications.
Let me write this out and then all you have to do is fill in the blank.
The 8 in an 8-32 thread specification refers to the Major Diameter.  The Major Diameter is equal to .... (this is where you fill in the blank information).
The 10 in a 10-24 thread specification refers to the Major Diameter.  The Major Diameter is equal to .... (this is where you fill in the blank information).
Message 22 of 60
JDMather
OK.
10 minutes has passed.  No decision made.
Let's limit the possible choices to those already mentioned in this thread.
8-32
10-24
12-24
Now it is narrowed to a multiple choice decision with 3 possible solutions. (Hint:  None of the solutions are incorrect.)
Pick one of the three.
Make your decision.
Message 23 of 60
I can't make any decision because now I am in a confused state. Let me go through each post again to clear the confusion.
Message 24 of 60
0.1640 inch \ 4.1656 mm
0.1900 inch \ 4.8260 mm
Message 25 of 60
JDMather
OK,
Now forget everything else and look only at Post #22.
Message 26 of 60
8-32
10-24
12-24
Make your decision.
8-32 is for the shaft so it was ruled out.
10-24 is for wing nut but this interfering with shaft therefore it was also ruled out.
12-24 this was selected in post 6 but I was told incorrect.
Therefore no matching thread for wing nut in this option.
Message 27 of 60
JDMather
@Anonymous wrote:
.... (Hint:  None of the solutions are incorrect.)
 I told you to pick one of them.
What is hard about that?
Who ruled this out?  Not me?  What did I write?
Didn't I write that whatever size was used - the same size has to be used for BOTH parts?
Who ruled this out? What happens if you push a screw into a nut without turning either?
Do they interfere or does the screw go through the hole in the nut?
Why were you told this was incorrect wingnut for your 8-32 shaft thread.
Could it be because this is a basic violation of the stated rule that whatever size was used - the same size has to be used for BOTH parts?
Since you couldn't make a decision - I will make it for you and then walk you through understanding threads.
Since your shaft is 8-32 UNC, lets pick that size for both the shaft and the wingnut.
So to be clear - I have made the decision it is 8-32 UNC (later we will see what happens if I had selected either of the other 2 sizes).
Let me work up starting example - back in a minute.
OK,
Open the Shaft part.
Start a new sketch on the XY Plane.
Project Geometry the top side of the cylindrical face and the end face as shown (green lines in image).
Create a Polygon with 3 sides.
Add a Horizontal constraint to one of the sides.
Dimension with the equation shown.
Message 28 of 60
This is what is coming. After that what to do?
Message 29 of 60
There is a another problem as well. In the cross section I couldn’t see any cross section of thread.
Message 30 of 60
Message 31 of 60
JDMather
No wonder you are having trouble understanding threads.  I thought we covered the topic of cosmetic thread representation vs modeled threads months ago.  I thought I instructed you to zoom wayyyy in on a cosmetic thread months ago.  The cosmetic thread is simply a picture wrapped around the shaft or hole - no real threads at all.
Message 32 of 60
I was explained before without any image therefore it was unclear. You can see I didn’t mark any solution as a acceptable one. Now only it is understandable and marked acceptable ones.
A picture is worth a thousand words - JDMather
http://forums.autodesk.com/t5/inventor-general-discussion/cosmetic-threads/td-p/6362166
Message 33 of 60
JDMather
I am uploading a video that will be ready in a few minutes.
While it uploads - I recommend that you review this image from Wikipedia....
and this page.
I seem to recall having given you this same information for AutoCAD (see attached document) 6 mths ago.
Note that there is a minor error at the end of the video where the horizontal line extends past the triangle.
I simply trim or drag that back the triangle to fully constrain.
Message 34 of 60
JDMather
Now cut the physical thread and compare to the cosmetic thread.
Then attach the Wing Nut here and I will demonstrate how to cut the internal thread and then test the assembly of the two components.
There might be a bit of confusion in the video as Inventor refers to the Coil Height (for length of thread) where I used the name Thread_Height for the distance from the root of the thread to the crest of the thread.  Note that these are two different "heights".
Message 35 of 60
This is an excellent video. This is a first time I come to know to convert cosmetic thread into model thread.
Thank you very much.
Message 36 of 60
JDMather
Uhmmm, you posted link to YouTube video for doing this 6 mths ago?
http://forums.autodesk.com/t5/autocad-mechanical-general/drawing-nut-and-bolt/td-p/6041792
And I gave you written step-by-step instructions 6 mths ago.
The process is all the same.
When you attach your Wingnut here - I will show how to properly create and test the internal threads.
Message 37 of 60
Is it a common practice to convert cosmetic thread into model thread if interference found?
Message 38 of 60
JDMather
How many times do I have to write this, "Didn't I write that whatever size was used - the same size has to be used for BOTH parts?"
Because you still don't understand that both mating parts must be the same size - I recommend that you go to your local hardware store and purchase the parts so that you have something physical in your hands to test.
Message 39 of 60
JDMather
Having trouble selecting the correct Wing Nut?
Hint:  If the shaft thread is 8-23 then the Wing Nut size must also be 8-32.
If the Wing Nut is 10-24 then the shaft thread is also 10-24.
See how this works now?
Two mating parts must have same thread sizes.
Message 40 of 60
I am working with other assignments to meet the deadline. Having completed that I will return to this work. I have other one as well from you.
