Interference detection graphics
armansesar
armansesar
Hello all, I didn't see a previous post covering this topic so wanted to post.
I recently updated to inventor 2025, from I believe 2022, from what I remember everything was the same until a recent app update, but now interference detection graphics appear triangulated, its much harder to see how much interference there is, previously it was a perfect display of what actually interfered. Please see the attached photo. Is there perhaps a setting I toggled by accident? thanks in advance.
pcrawley
That's not good - it looks like a Beehive starting to grow on your model!
My 2025.2 shows interference as expected:
  • Do you have the problem with just one model - or all models?
  • Is the screenshot from imported geometry or something you've modelled?
    (Could it be the interference between 2 meshes - I don't have anything here to see if I get the same result.)
  • Has anything changed with your hardware spec's?
Peter
armansesar
Thank you so much, after reading your response, I immediately knew it was most likely due to a mesh I was designing around in one of the parts. I don't typically use these .STL meshes so its not something I was experienced with. Although, even suppressing the mesh features didn't seem to resolve the issue, and I had to completely delete it to get rid of the bee hive 😄 thanks again.
