Hey guys, after years of using Inventor, I'm beginning to have all sort of basic problems, not sure if it is update related, but never before have I experience this issue. Typically, in the assembly environment, I go about constraining my parts using faces, edges, planes...etc. Then I can simply move the part to have it snap in place, or move it slightly to see what planes still need constraining. However, since the recent upgrade, I continuously have to select what elements I want to select in the selection priority menu, for example, If i want to constrain a face to an edge, then the 'select faces and edges' option needs to be selected. But then immediately after, I need to go back to the drop down, and select part priority to be able to move the part. And then I have to go back and 'select faces and edges' again and so on. You can see how this can be bothersome in a large assembly that's already chorus to constrain. This was not at all a problem before.
If you notice my recent posts, all are rather basic functions that I'm having difficulty with. I'm not sure why Autodesk is updating features that have been consistent for many years, or perhaps I'm doing something on my end that is the cause of my frustration. Either way, I'd appreciate your input, and hope Autodesk would stop making unnecessary changes to what works.
