selection priority while constraining
armansesar
armansesar
Hey guys, after years of using Inventor, I'm beginning to have all sort of basic problems, not sure if it is update related, but never before have I experience this issue. Typically, in the assembly environment, I go about constraining my parts using faces, edges, planes...etc. Then I can simply move the part to have it snap in place, or move it slightly to see what planes still need constraining. However, since the recent upgrade, I continuously have to select what elements I want to select in the selection priority menu, for example, If i want to constrain a face to an edge, then the 'select faces and edges' option needs to be selected. But then immediately after, I need to go back to the drop down, and select part priority to be able to move the part. And then I have to go back and 'select faces and edges' again and so on. You can see how this can be bothersome in a large assembly that's already chorus to constrain. This was not at all a problem before.
If you notice my recent posts, all are rather basic functions that I'm having difficulty with. I'm not sure why Autodesk is updating features that have been consistent for many years, or perhaps I'm doing something on my end that is the cause of my frustration. Either way, I'd appreciate your input, and hope Autodesk would stop making unnecessary changes to what works.
pcrawley
You don't mention version you are running or the update you think may have introduced the problem?
I've been using 2022, 2023 and not 2025.2 over the last 12 months and don't think I've experienced such behaviour.
You mentioned "I can simply move the part to have it snap in place" - that sounds like you have "Defer Update" enabled (in Tools > Application Options > Assembly).
"If i want to constrain a face to an edge, then the 'select faces and edges' option needs to be selected." - So, if "Component Priority" is selected, then you start the Constraint Tool - are you saying you can't select faces and edges?  That does sound a bit broken!  Any chance of a video/screenshots?
Peter
armansesar
thanks, it looks like this was my fault, I am running 2025.2 as well. I was able to return to the normal functionality by setting to the Inventors preferred 'select component priority' option in the assembly environment, however, It used to show a preview of what you were about to select both when setting constraints and measuring, now it does not. I have to click on the surface or edge I want and hope the correct element is selected. I do prefer the defer update option so that's not really an issue for me, thanks..
pcrawley
Glad it is working as expected.
"It used to show a preview of what you were about to select both when setting constraints and measuring"
Tools > Application Options > Colors - "Enable Prehighlight" is probably unchecked.  (Note that the three options here change when switching from Dark to Light UI Themes.  That's caught me out a couple of times!)
"I do prefer the defer update option" - I do too in some cases, which is why it is handy to have it as an option.  We used to use it all the time when constraining large adaptive subassemblies into place.  It meant we could add 6 constraints and then let the subassembly recompute, rather than recomputing with every constraint.  It saved hours per day.
(If the information provided an answer your question, please use Accept Solution so that others may find this in the future.)
Peter
armansesar
Yes without the defer update, sometimes you have to go hunt for the part again, after applying the initial constraint, and thank you again, that solved the highlighting issue as well.
