Installing Australian Standard (iFeature) steel section library
Hello forum
I have installed Inventor 2017 from the Autodesk website.
However there does not seem to be Australian Standard (AS) content in the "insert iFeature" section. These files have an *.ide extension.
The file path for the installed features are under C:\Users\Public\Documents\Autodesk\Inventor 2017\Catalog\Geometric Shapes.
The workflow that I used with Inventor 2015 was (in a part file *.ipt), Insert iFeature > select (2D) AS geometric shape > extrude to length.
I cannot seem to replicate this workflow with Inventor 2017.
I can place AS sections from Content Centre in an assembly but I want to build a multibody mechanical frame in a part file using AS steel sections.
Please find screen shot of ide files
Have I overlooked something?
Thanks in advance.
Basically what I am trying to achieve is the ability to insert AS Geometric Steel Section (2D) profiles (available from a library) into a sketch. The profiles can then be extruded to create a multibody mechanical frame.
AS Geometric Steel Section *.ide files copied into catalog directory
DesignStainless
Did you download or make the .ide files yourself? Is there any chance you could share the files?
Cheers
Giuseppe_Origine9S5JK
Does anyone know where I can find the Australian standard library?
