Installation failed for Inventor 2015
Here's the Installation log files and a screen in the attachments:
=== Setup started on STARWARS by Angelo ===
2015/1/4:14:53:39 Angelo STARWARS Path_Length: 155
2015/1/4:14:53:39 Angelo STARWARS Current Directory C:\Autodesk\Autodesk_Inventor_2015_R1_Italian_Win_64bit_wi_it-IT
2015/1/4:14:53:39 Angelo STARWARS Launch
2015/1/4:14:53:39 Angelo STARWARS CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_R1_Italian_Win_64bit_w... /SN 900-49214987 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2015/1/4:14:53:39 Angelo STARWARS Current Directory C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp
2015/1/4:14:54:39 Angelo STARWARS === Setup ended ===
2015/1/4:14:53:40 Angelo STARWARS === Setup started on STARWARS by Angelo ===
2015/1/4:14:53:40 Angelo STARWARS Path_Length: 155
2015/1/4:14:53:40 Angelo STARWARS Current Directory C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp
2015/1/4:14:53:40 Angelo STARWARS Launch
2015/1/4:14:54:38 Angelo STARWARS Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/SETUP_...
2015/1/4:14:54:38 Angelo STARWARS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\Setup\InventorUI.dll
2015/1/4:14:54:38 Angelo STARWARS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/1/4:14:54:39 Angelo STARWARS PageOpen LaunchDialog
2015/1/4:14:56:57 Angelo STARWARS Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\Setup\InventorUI.dll
2015/1/4:14:56:57 Angelo STARWARS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/1/4:14:56:57 Angelo STARWARS Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message:
2015/1/4:14:56:57 Angelo STARWARS Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\Setup\InventorUI.dll
2015/1/4:14:56:57 Angelo STARWARS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2015/1/4:14:56:57 Angelo STARWARS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:2 InstallAction:0 Message:
2015/1/4:14:59:44 Angelo STARWARS PageOpen LicenseDialog
2015/1/4:14:59:44 Angelo STARWARS PageOpen ProductInfoDialog
2015/1/4:14:59:44 Angelo STARWARS PageOpen InventorFlavorSelectionDialog
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DefaultLanguage: it-it
2015/1/4:14:59:44 Angelo STARWARS Inventorui==InstallName: INVENTOR
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ProductName: Autodesk Inventor 2015
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DisplayName: Autodesk® Inventor® 2015
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DeploymentName:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SetupTitle: Autodesk Inventor 2015
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ConfigTransform:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ExeParams:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4}
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SupportLink:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==InfotainmentLink:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==MsiFileName: inventor.msi
2015/1/4:14:59:44 Angelo STARWARS Inventorui==AdminImageConfigName: Imgx64
2015/1/4:14:59:44 Angelo STARWARS Inventorui==AdminImageRoot:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==GetBaseDeploymentName:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DeploymentLocation:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-ita
2015/1/4:14:59:44 Angelo STARWARS Inventorui==InstallDeploymentShortcut:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ModifyDeploymentShortcut:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SetupLockType: 2
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SetupNetworkType: 1
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SystemLocale: 1040
2015/1/4:14:59:44 Angelo STARWARS Inventorui==EvalMsiFilePath: C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\SetupRes\eval.msi
2015/1/4:14:59:44 Angelo STARWARS Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA
2015/1/4:14:59:44 Angelo STARWARS Inventorui==InstallLogPath: C:\Users\Angelo\AppData\Local\Temp\Inventor2015Install.log
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ConfigFile: C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\Setup.ini
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SetupPath: C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\
2015/1/4:14:59:44 Angelo STARWARS Inventorui==NetworkLogPath:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015
2015/1/4:15:01:31 Angelo STARWARS Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2015/1/4:15:01:31 Angelo STARWARS PageOpen ProductSelectionDialog2
2015/1/4:15:14:15 Angelo STARWARS PageOpen FullProgressDialog
2015/1/4:15:14:17 Angelo STARWARS Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/VCREDI...
2015/1/4:15:14:29 Angelo STARWARS Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/VCREDI...
2015/1/4:15:14:29 Angelo STARWARS Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Angelo\AppData\Local\Temp\vcredist_x86_2012.log
2015/1/4:15:15:23 Angelo STARWARS Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/1/4:15:15:23 Angelo STARWARS Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/VCREDI...
2015/1/4:15:15:39 Angelo STARWARS Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/VCREDI...
2015/1/4:15:15:39 Angelo STARWARS Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Angelo\AppData\Local\Temp\vcredist_x64_2012.log
2015/1/4:15:16:25 Angelo STARWARS Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/1/4:15:16:26 Angelo STARWARS Download Play CMILL http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/CMILL....
2015/1/4:15:22:46 Angelo STARWARS Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/CMILL....
2015/1/4:15:22:46 Angelo STARWARS Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
DannyHubbard
From the log file it appears that download failed.
I would recommend trying the other download methods, like the Download Now or Browser Download options.
http://knowledge.autodesk.com/topics/account-management/software-downloads/download-methods/educatio...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
I tried the unique alternative download method "Browser download". I did it from mozilla because chrome doesn't download the second file needed for the complete installation. I opened the first file and extracted in (C: ) Autodesk. At the end of the process I started the installation but an error occured with the message screened and added as attachment. I don't find anything as "MaterialLibrary2015.msi" or "Material Library 2015" on Autodesk site.
DannyHubbard
If you were able to download both files and everything extracted correctly you should find the material installers at something like.
"C:\Autodesk\Autodesk_Inventor_2015_<lang>_Win_64bit_dlm\Content\ADSKMaterials\2015"
If this folder doesn't exist I would recommend running the first executable again to try extracting everything again.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
I found and opened it and it sayd me I can only repair or unistall, but clicking on repair, it start the setup, so I successfully installed "MaterialLIbrary2015.msi", but running the Inv 2015 setup it show me the same error message. It sounds me strange that I installed the requested file that it say me it's not installed 😕
In the folder "ADSKMaterials" > "2015" there are 3 folders "CM", "ILB" and "ILL". In "CM" I found the "MaterialLibrary2015.msi". In "ILB" I found "BaseImageLibrary2015.msi", so I installed it too, in "ILL" I found "LowImageLibrary2015.msi", but it don't let me do the installation showing me the same error message showed by Inv 2015.
What can I do now?..
