Installation failed for Inventor 2015
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Here's the Installation log files and a screen in the attachments:
=== Setup started on STARWARS by Angelo ===
2015/1/4:14:53:39 Angelo STARWARS Path_Length: 155
2015/1/4:14:53:39 Angelo STARWARS Current Directory C:\Autodesk\Autodesk_Inventor_2015_R1_Italian_Win_64bit_wi_it-IT
2015/1/4:14:53:39 Angelo STARWARS Launch
2015/1/4:14:53:39 Angelo STARWARS CommandLine /url "http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/Autodesk_Inventor_2015_R1_Italian_Win_64bit_w... /SN 900-49214987 /PK 797G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2015/1/4:14:53:39 Angelo STARWARS Current Directory C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp
2015/1/4:14:54:39 Angelo STARWARS === Setup ended ===
2015/1/4:14:53:40 Angelo STARWARS === Setup started on STARWARS by Angelo ===
2015/1/4:14:53:40 Angelo STARWARS Path_Length: 155
2015/1/4:14:53:40 Angelo STARWARS Current Directory C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp
2015/1/4:14:53:40 Angelo STARWARS Launch
2015/1/4:14:54:38 Angelo STARWARS Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/SETUP_...
2015/1/4:14:54:38 Angelo STARWARS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\Setup\InventorUI.dll
2015/1/4:14:54:38 Angelo STARWARS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/1/4:14:54:39 Angelo STARWARS PageOpen LaunchDialog
2015/1/4:14:56:57 Angelo STARWARS Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\Setup\InventorUI.dll
2015/1/4:14:56:57 Angelo STARWARS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/1/4:14:56:57 Angelo STARWARS Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message:
2015/1/4:14:56:57 Angelo STARWARS Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\Setup\InventorUI.dll
2015/1/4:14:56:57 Angelo STARWARS Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2015/1/4:14:56:57 Angelo STARWARS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:2 InstallAction:0 Message:
2015/1/4:14:59:44 Angelo STARWARS PageOpen LicenseDialog
2015/1/4:14:59:44 Angelo STARWARS PageOpen ProductInfoDialog
2015/1/4:14:59:44 Angelo STARWARS PageOpen InventorFlavorSelectionDialog
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DefaultLanguage: it-it
2015/1/4:14:59:44 Angelo STARWARS Inventorui==InstallName: INVENTOR
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ProductName: Autodesk Inventor 2015
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DisplayName: Autodesk® Inventor® 2015
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DeploymentName:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SetupTitle: Autodesk Inventor 2015
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ConfigTransform:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ExeParams:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4}
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SupportLink:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==InfotainmentLink:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==MsiFileName: inventor.msi
2015/1/4:14:59:44 Angelo STARWARS Inventorui==AdminImageConfigName: Imgx64
2015/1/4:14:59:44 Angelo STARWARS Inventorui==AdminImageRoot:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==GetBaseDeploymentName:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DeploymentLocation:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-ita
2015/1/4:14:59:44 Angelo STARWARS Inventorui==InstallDeploymentShortcut:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ModifyDeploymentShortcut:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SetupLockType: 2
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SetupNetworkType: 1
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SystemLocale: 1040
2015/1/4:14:59:44 Angelo STARWARS Inventorui==EvalMsiFilePath: C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\SetupRes\eval.msi
2015/1/4:14:59:44 Angelo STARWARS Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2015\EULA
2015/1/4:14:59:44 Angelo STARWARS Inventorui==InstallLogPath: C:\Users\Angelo\AppData\Local\Temp\Inventor2015Install.log
2015/1/4:14:59:44 Angelo STARWARS Inventorui==ConfigFile: C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\Setup.ini
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SetupPath: C:\Users\Angelo\AppData\Local\Temp\_AI6A76.tmp\
2015/1/4:14:59:44 Angelo STARWARS Inventorui==NetworkLogPath:
2015/1/4:14:59:44 Angelo STARWARS Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2015
2015/1/4:15:01:31 Angelo STARWARS Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2015/1/4:15:01:31 Angelo STARWARS PageOpen ProductSelectionDialog2
2015/1/4:15:14:15 Angelo STARWARS PageOpen FullProgressDialog
2015/1/4:15:14:17 Angelo STARWARS Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/VCREDI...
2015/1/4:15:14:29 Angelo STARWARS Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/VCREDI...
2015/1/4:15:14:29 Angelo STARWARS Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Angelo\AppData\Local\Temp\vcredist_x86_2012.log
2015/1/4:15:15:23 Angelo STARWARS Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2015/1/4:15:15:23 Angelo STARWARS Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/VCREDI...
2015/1/4:15:15:39 Angelo STARWARS Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/VCREDI...
2015/1/4:15:15:39 Angelo STARWARS Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Inventor 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Angelo\AppData\Local\Temp\vcredist_x64_2012.log
2015/1/4:15:16:25 Angelo STARWARS Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2015/1/4:15:16:26 Angelo STARWARS Download Play CMILL http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/CMILL....
2015/1/4:15:22:46 Angelo STARWARS Download Aborted CMILL http://edutrial.autodesk.com/SWDLDNET4/2015/INVNTOR/WI/{4935E336-AB37-406A-A97B-1AEAC853758C}/CMILL....
2015/1/4:15:22:46 Angelo STARWARS Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
