Insert Image to sketch around
jazzking2001
jazzking2001
I was wondering, is it possible to import an image into inventor so that i can sketch around it?
For example, I take a image of a TV remote. I want to import that image into inventor so that i would be able to sketch around the outline of tv remote.
I think using this method, it would be much faster than trying to get the dimensions of whatever item i took a image of.
Instead of a tv remote, i need to create an outline of something more complicated, I do not have the skills nor the time to visually try to recreate whatever item. Thus, being about the use a image in inventor would just much simpler to create an outline.
thanks
Cadmanto
Take a look at the attached thread to see if this helps you.
https://forums.autodesk.com/t5/inventor-forum/can-i-import-picture-in-autodesk-inventor-and-extrude-...
Here is an instructional video that might help you as well.
https://www.youtube.com/watch?v=YN_4ou8STe8
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
leowarren34
Just make to lock the image so you dont drag it around
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
johnsonshiue
Hi! Like other experts have mentioned, you can insert an image to a sketch. Then manually trace the lines using 2D sketch commands. If you have access to AutoCAD, you could use Raster Design to convert the image to vector lines/curves.
Many thanks!
Software Test Engineer
jazzking2001
Thanks for the information you have provided.
I am having an issue with image scaling when i insert it into inventor.
I am trying to trac the handle base of the NES ZAPPER GUN. I took a picture of it to trace. When i open the image on my desktop, the size of the base is the same as the physical gun.
However, when i insert it into inventor, and start tracing it with lines, i have an issue. The lines i track are all way way too long.
For example, a part i traced should be 1.125 inches long. This is how it for the physical gun and the image i took. However, in inventor the line is something like 25 inches long.
johnsonshiue
Hi! I see the issue now. You are talking about scaling the image to true size. I guess you may want to edit the image in an editor like Paint and set the image size accordingly. Then insert it to Inventor sketch. Another option is to create a rectangle in the sketch. Dimension the rectangle to the desirable scale. Insert the image and drag the image so it fills the rectangle.
Many thanks!
TheCADWhisperer
1. Place image in sketch.
2. Sketch line across a portion of image that you know true size.
3. Dimension the line true size.
The image will automatically scale to true size.
Easy peasy!
