I sat down with our IT guy and we analyzed the logfile ourselves. We found that Inventor was repeatedly trying to access CN-6408.0015.ipt and failing. There is no such version for that file in my local or in Vault. This is a long-standing bug with a history of fixes and reintroductions. https://forums.autodesk.com/t5/vault-forum/inventor-looks-for-a-version-that-doesn-t-exist/td-p/1212... Normally, an error message is shown that allows the user to ignore the reference glitch and proceed. My Inventor client was not sending the message and just looped back. We manually created a file CN-6408.0015.ipt in the related directory and the bug was fixed.
Now we know this is unrelated to Webroot, Huntress, or another application. This is a bug in Inventor itself.
Here is the bottom of Process Monitor's output, showing Inventor trying over and over to find CN-6408.ipt version 19.
11:14:04.9529814 Inventor.exe 14440 CreateFileMapping C:\Vault_Local\Designs\CN-\CN-6408.ipt FILE LOCKED WITH ONLY READERS SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE_WRITECOPY
11:14:04.9529897 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9530043 Inventor.exe 14440 CreateFileMapping C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS SyncType: SyncTypeOther
11:14:04.9530183 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9530380 Inventor.exe 14440 QueryBasicInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS CreationTime: 11/28/2022 14:35:25, LastAccessTime: 11/19/2024 11:14:04, LastWriteTime: 11/28/2022 14:35:24, ChangeTime: 11/19/2024 11:12:00, FileAttributes: RA
11:14:04.9530460 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,538, Length: 1, Fail Immediately: True
11:14:04.9530549 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,559, Length: 20, Fail Immediately: True
11:14:04.9530628 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,559, Length: 20
11:14:04.9530706 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,579, Length: 20, Fail Immediately: True
11:14:04.9530781 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,579, Length: 20
11:14:04.9530880 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,538, Length: 1
11:14:04.9531480 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
11:14:04.9531989 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt NAME NOT FOUND Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a
11:14:04.9532477 Inventor.exe 14440 CloseFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS
11:14:04.9533439 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a, OpenResult: Opened
11:14:04.9533656 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9533763 Inventor.exe 14440 CreateFileMapping C:\Vault_Local\Designs\CN-\CN-6408.ipt FILE LOCKED WITH ONLY READERS SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE_WRITECOPY
11:14:04.9533849 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9534015 Inventor.exe 14440 CreateFileMapping C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS SyncType: SyncTypeOther
11:14:04.9534157 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9534367 Inventor.exe 14440 QueryBasicInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS CreationTime: 11/28/2022 14:35:25, LastAccessTime: 11/19/2024 11:14:04, LastWriteTime: 11/28/2022 14:35:24, ChangeTime: 11/19/2024 11:12:00, FileAttributes: RA
11:14:04.9534450 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,538, Length: 1, Fail Immediately: True
11:14:04.9534536 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,559, Length: 20, Fail Immediately: True
11:14:04.9534616 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,559, Length: 20
11:14:04.9534693 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,579, Length: 20, Fail Immediately: True
11:14:04.9534768 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,579, Length: 20
11:14:04.9534843 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,538, Length: 1
11:14:04.9535427 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
11:14:04.9535911 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt NAME NOT FOUND Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a
11:14:04.9536364 Inventor.exe 14440 CloseFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS
11:14:04.9537361 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a, OpenResult: Opened
11:14:04.9537595 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9537704 Inventor.exe 14440 CreateFileMapping C:\Vault_Local\Designs\CN-\CN-6408.ipt FILE LOCKED WITH ONLY READERS SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE_WRITECOPY
11:14:04.9537790 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9537960 Inventor.exe 14440 CreateFileMapping C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS SyncType: SyncTypeOther
11:14:04.9538102 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9538332 Inventor.exe 14440 QueryBasicInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS CreationTime: 11/28/2022 14:35:25, LastAccessTime: 11/19/2024 11:14:04, LastWriteTime: 11/28/2022 14:35:24, ChangeTime: 11/19/2024 11:12:00, FileAttributes: RA
11:14:04.9538424 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,538, Length: 1, Fail Immediately: True
11:14:04.9538517 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,559, Length: 20, Fail Immediately: True
11:14:04.9538601 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,559, Length: 20
11:14:04.9538681 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,579, Length: 20, Fail Immediately: True
11:14:04.9538756 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,579, Length: 20
11:14:04.9538832 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,538, Length: 1
11:14:04.9539499 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
11:14:04.9540050 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt NAME NOT FOUND Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a
11:14:04.9540545 Inventor.exe 14440 CloseFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS
11:14:04.9541500 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a, OpenResult: Opened
11:14:04.9541711 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9541811 Inventor.exe 14440 CreateFileMapping C:\Vault_Local\Designs\CN-\CN-6408.ipt FILE LOCKED WITH ONLY READERS SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE_WRITECOPY
11:14:04.9541894 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9542042 Inventor.exe 14440 CreateFileMapping C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS SyncType: SyncTypeOther
11:14:04.9542182 Inventor.exe 14440 QueryStandardInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9542406 Inventor.exe 14440 QueryBasicInformationFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS CreationTime: 11/28/2022 14:35:25, LastAccessTime: 11/19/2024 11:14:04, LastWriteTime: 11/28/2022 14:35:24, ChangeTime: 11/19/2024 11:12:00, FileAttributes: RA
11:14:04.9542509 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,538, Length: 1, Fail Immediately: True
11:14:04.9542598 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,559, Length: 20, Fail Immediately: True
11:14:04.9542681 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,559, Length: 20
11:14:04.9542761 Inventor.exe 14440 LockFile C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Exclusive: True, Offset: 2,147,483,579, Length: 20, Fail Immediately: True
11:14:04.9542859 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,579, Length: 20
11:14:04.9542935 Inventor.exe 14440 UnlockFileSingle C:\Vault_Local\Designs\CN-\CN-6408.ipt SUCCESS Offset: 2,147,483,538, Length: 1
11:14:04.9543570 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
11:14:04.9544084 Inventor.exe 14440 CreateFile C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt NAME NOT FOUND Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a
11:14:04.9544549 Inventor.exe 14440 CloseFile C:\Vault_Local\Designs\CN-\CN-6408.ipt
Version 19 never existed.
