ERROR 93
ERROR 93
mafernandezsa
ERROR 93
mafernandezsa
I have a problem for to open a file IPT.
If i open de file, i see the screen.
Gabriel_Watson
Sometimes you just need a reboot after installing Inventor or an update, to properly close the process.
mafernandezsa
I am going to explain the case a little more.
1.- This error screen (Error 93) appeared on a Computer1 that had Autodesk Inventor v.2023 installed for quite some time.
2.- On a Computer2 a piece was generated in v.2023. This computer had v.2023 and v.2024 installed.
3.- That part generated on computer2 opens on computer1 and that's when error 93 appears.
4.- I have tried to insert the part into another one to be able to lean on, but I get an error in the containing piece, as if I had not saved the operations or it was corrupted.
Gabriel_Watson
Not enough information about the part (was it generated by design accelerator? does it contain iLogic? does it contain anything else that perhaps was added in 2024 without you knowing?). And not enough information about the other error you saw.
cdbussey
I've seen strange errors when files have been created on pc's with multiple versions of Inventor running on them. I'm not 100% convinced this is the issue, but in some cases, I was able to get things working by making sure which version of Inventor (ApprenticeRegSvr.exe) was registered currently with the OS. I would attempt to open the model in Inventor 2024, save it out as a neutral format (IGES/SAT), then bring the neutral file back into Inventor 2023 and convert it back to an ipt file. If you are using Vault, you will likely need to remove the existing file that is corrupt, then add the newly created file to Vault, then go about repairing the assemblies where the old file was used.
johnsonshiue
Hi! I am sorry I don't read Portuguese. Can anybody share the English translation of the message in the dialog? I would like to understand the issue better.
Many thanks!
Software Test Engineer
