Infinitely Loading When Opening Assemblies
cstarker6VCG4
Message 1 of 42
cstarker6VCG4
Inventor has developed the lovely habit of loading infinitely, requiring a hard close, when opening assemblies from either Vault or the model tree. Memory and CPU usage remains normal. I can't wait to see if it will resolve unattended and am forced to restart Inventor to fix it which is not guaranteed. There is no error message or pattern to this other than it happens about every fifth open. Of course, this is insanely disruptive.
I assume the latest patch was the cause.
Replies (41)
Message 41 of 42
cstarker6VCG4
I sat down with our IT guy and we analyzed the logfile ourselves. We found that Inventor was repeatedly trying to access CN-6408.0015.ipt and failing. There is no such version for that file in my local or in Vault. This is a long-standing bug with a history of fixes and reintroductions. https://forums.autodesk.com/t5/vault-forum/inventor-looks-for-a-version-that-doesn-t-exist/td-p/1212... Normally, an error message is shown that allows the user to ignore the reference glitch and proceed. My Inventor client was not sending the message and just looped back. We manually created a file CN-6408.0015.ipt in the related directory and the bug was fixed.
Now we know this is unrelated to Webroot, Huntress, or another application. This is a bug in Inventor itself.
Here is the bottom of Process Monitor's output, showing Inventor trying over and over to find CN-6408.ipt version 19.
11:14:04.9529814	Inventor.exe	14440	CreateFileMapping	C:\Vault_Local\Designs\CN-\CN-6408.ipt	FILE LOCKED WITH ONLY READERS	SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE_WRITECOPY
11:14:04.9529897	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9530043	Inventor.exe	14440	CreateFileMapping	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	SyncType: SyncTypeOther
11:14:04.9530183	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9530380	Inventor.exe	14440	QueryBasicInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	CreationTime: 11/28/2022 14:35:25, LastAccessTime: 11/19/2024 11:14:04, LastWriteTime: 11/28/2022 14:35:24, ChangeTime: 11/19/2024 11:12:00, FileAttributes: RA
11:14:04.9530460	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,538, Length: 1, Fail Immediately: True
11:14:04.9530549	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,559, Length: 20, Fail Immediately: True
11:14:04.9530628	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,559, Length: 20
11:14:04.9530706	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,579, Length: 20, Fail Immediately: True
11:14:04.9530781	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,579, Length: 20
11:14:04.9530880	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,538, Length: 1
11:14:04.9531480	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt	NAME NOT FOUND	Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
11:14:04.9531989	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt	NAME NOT FOUND	Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a
11:14:04.9532477	Inventor.exe	14440	CloseFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS
11:14:04.9533439	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a, OpenResult: Opened
11:14:04.9533656	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9533763	Inventor.exe	14440	CreateFileMapping	C:\Vault_Local\Designs\CN-\CN-6408.ipt	FILE LOCKED WITH ONLY READERS	SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE_WRITECOPY
11:14:04.9533849	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9534015	Inventor.exe	14440	CreateFileMapping	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	SyncType: SyncTypeOther
11:14:04.9534157	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9534367	Inventor.exe	14440	QueryBasicInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	CreationTime: 11/28/2022 14:35:25, LastAccessTime: 11/19/2024 11:14:04, LastWriteTime: 11/28/2022 14:35:24, ChangeTime: 11/19/2024 11:12:00, FileAttributes: RA
11:14:04.9534450	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,538, Length: 1, Fail Immediately: True
11:14:04.9534536	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,559, Length: 20, Fail Immediately: True
11:14:04.9534616	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,559, Length: 20
11:14:04.9534693	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,579, Length: 20, Fail Immediately: True
11:14:04.9534768	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,579, Length: 20
11:14:04.9534843	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,538, Length: 1
11:14:04.9535427	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt	NAME NOT FOUND	Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
11:14:04.9535911	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt	NAME NOT FOUND	Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a
11:14:04.9536364	Inventor.exe	14440	CloseFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS
11:14:04.9537361	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a, OpenResult: Opened
11:14:04.9537595	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9537704	Inventor.exe	14440	CreateFileMapping	C:\Vault_Local\Designs\CN-\CN-6408.ipt	FILE LOCKED WITH ONLY READERS	SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE_WRITECOPY
11:14:04.9537790	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9537960	Inventor.exe	14440	CreateFileMapping	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	SyncType: SyncTypeOther
11:14:04.9538102	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9538332	Inventor.exe	14440	QueryBasicInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	CreationTime: 11/28/2022 14:35:25, LastAccessTime: 11/19/2024 11:14:04, LastWriteTime: 11/28/2022 14:35:24, ChangeTime: 11/19/2024 11:12:00, FileAttributes: RA
11:14:04.9538424	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,538, Length: 1, Fail Immediately: True
11:14:04.9538517	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,559, Length: 20, Fail Immediately: True
11:14:04.9538601	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,559, Length: 20
11:14:04.9538681	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,579, Length: 20, Fail Immediately: True
11:14:04.9538756	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,579, Length: 20
11:14:04.9538832	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,538, Length: 1
11:14:04.9539499	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt	NAME NOT FOUND	Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
11:14:04.9540050	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt	NAME NOT FOUND	Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a
11:14:04.9540545	Inventor.exe	14440	CloseFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS
11:14:04.9541500	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a, OpenResult: Opened
11:14:04.9541711	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9541811	Inventor.exe	14440	CreateFileMapping	C:\Vault_Local\Designs\CN-\CN-6408.ipt	FILE LOCKED WITH ONLY READERS	SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE_WRITECOPY
11:14:04.9541894	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9542042	Inventor.exe	14440	CreateFileMapping	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	SyncType: SyncTypeOther
11:14:04.9542182	Inventor.exe	14440	QueryStandardInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	AllocationSize: 634,880, EndOfFile: 633,856, NumberOfLinks: 1, DeletePending: False, Directory: False
11:14:04.9542406	Inventor.exe	14440	QueryBasicInformationFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	CreationTime: 11/28/2022 14:35:25, LastAccessTime: 11/19/2024 11:14:04, LastWriteTime: 11/28/2022 14:35:24, ChangeTime: 11/19/2024 11:12:00, FileAttributes: RA
11:14:04.9542509	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,538, Length: 1, Fail Immediately: True
11:14:04.9542598	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,559, Length: 20, Fail Immediately: True
11:14:04.9542681	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,559, Length: 20
11:14:04.9542761	Inventor.exe	14440	LockFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Exclusive: True, Offset: 2,147,483,579, Length: 20, Fail Immediately: True
11:14:04.9542859	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,579, Length: 20
11:14:04.9542935	Inventor.exe	14440	UnlockFileSingle	C:\Vault_Local\Designs\CN-\CN-6408.ipt	SUCCESS	Offset: 2,147,483,538, Length: 1
11:14:04.9543570	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt	NAME NOT FOUND	Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
11:14:04.9544084	Inventor.exe	14440	CreateFile	C:\Vault_Local\Designs\CN-\OldVersions\CN-6408.0019.ipt	NAME NOT FOUND	Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a
11:14:04.9544549	Inventor.exe	14440	CloseFile	C:\Vault_Local\Designs\CN-\CN-6408.ipt
Version 19 never existed.
Message 42 of 42
johnsonshiue
Hi Colin,
Many thanks for sharing the findings! Inventor does not open files from Old Versions folder directly. It seems that Vault initiates the request. I need to work with the project team to understand it better.
Thanks again!
Software Test Engineer
