Blair,
I found a reference in the 29th machinery handbook for "American National Standard Straight Pipe Threads for Mechanical Joints, NPSM and NPSL, ANSI/ASME B1.20.1-1983" with the thread diameters you listed. I don't believe those apply to NPT thread. There is a standard diagram showing the basic dimensions of the NPT thread. The E1 dimension ( defined as 'the pitch diameter at the large end of the the internal thread end at the gaging notch" defines the big hole size. I see that is 1.82234. Subtract a thread height and you should get the required minor diameter.
Anyhow, I'm not too concerned with the exact diameter measurements. To mill a part that gages properly I can adjust offsets to get the target size. The wrong taper angle is troublesome because HSM ( the CAM program that integrates with Inventor) uses the taper angle of the hole to generate the tool path. So, in order to properly mill the part, I have to manually define the hole instead of using the built-in hole function. What a PITA.
Martins.
