Spur & Bevel Gear Generator
Hi
I want to make this(according to the picture) to 2 real gear with Spur gears Generator. but I don't know.
anyone can show me with video.Smiley Frustrated
thanks in advanced
kelly.young has edited your subject line for clarity: Super gears Generator
johnsonshiue
Hi! I think you are looking for bevel gears in Design Accelerator. Below is a link to the help document. You can do a search on Autodesk Knowledge Network to find related documents or videos.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
@Anonymous to add to what @johnsonshiue shared, search through the forum by keyword and see if any of the previous posts help.
There are also quite a few videos on youtube regarding bevel gear creation that are fairly in-depth. If you have gotten fairly far and get stuck you can always post your files and see if the community can point you in the right direction!
Please select the Accept as Solution button if a post solves your issue or answers your question.
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I am checking back to see if any of the replies helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Select the Accept as Solution button if a post or posts solves your issue or answers your question.
