incompatible units error on parts list
jason_mcowenPBP7J
Message 1 of 9
jason_mcowenPBP7J
Good Afternoon,
trying to finalise a weldment detail and the parts list has to rows in the length column that states " incompatible units error". I cant see where this is coming from and why this is happening, I even tried to override manually the value and it came up with a weird number?
Any ideas as its driving me round the bend?
Kind Regards
Jason
Replies (8)
Message 2 of 9
Gabriel_Watson
Message 3 of 9
CStilesCARE
The 3rd column in the table you pictured shows that the rows giving you issues consist of multiple parts which were "rolled up" together (shows an icon like a sideways bar graph instead of the cube). It's possible that 1 or more of those parts have been set to different units than the others, so I'd open up each of those parts (or check parts-only BOM in assembly) to see what they're set at and make sure all are the same.
Message 4 of 9
jason_mcowenPBP7J
this could be the cause as I have noticed with this current release of Inventor, even thought the template has been set to metric, it still displayed imperial units. So definitely a bug in there somewhere.
Message 5 of 9
johnsonshiue
Hi Jason,
I would like to see an example of unit reset. I am not aware of such behavior. I think this issue could be related to incompatible unit or substituted values. Please share the files in zip here or send it to me directly [email protected]. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 6 of 9
pcrawley
@jason_mcowenPBP7J wrote:
..... I have noticed with this current release of Inventor, even thought the template has been set to metric, it still displayed imperial units. So definitely a bug in there somewhere.
The Document Settings > Units in the Content Center template for your problem components is set to imperial units.  When you look at the BOM in a model, or the Parts List on the drawing, the unit/decimal place information on parts comes from the part-level Document Settings.
In Inventor 2022 (I think) they added a tickbox called" Use Assembly Units" which is brilliant.  (See Tools > Application Options > File > "File Naming Defaults...")
Peter
Message 7 of 9
pcrawley
Oops - deleted duplicate post 🙂
Peter
Message 8 of 9
jason_mcowenPBP7J
I believe, this is the issue I was having and I was directed to a forum topic by a colleague in the states.
Unit Qty "Varies" in BOM from Frame Generator - Autodesk Community - Inventor
I'm satisfied for now, I have other issues which I will create another forum post for.
Many Thanks for you time 🙂
Message 9 of 9
Detlefb_aeza
Community Visitor
Community Visitor
Changing the group setting solved the error, but displayed all parent assemblies, which I do not want. In my case the error is coming from having the same part at multiple assembly levels. The assembly is built as it would be fabricated, so changing that is not really an option.
