Is it possible to include a working axis from another location in a 3d sketch?
I tried to add another work axis, but I still can't include it
I currently need to draw a sketch that simulates the working axis. Is it necessary to do this?
Solved by Alexander_Chernikov. Go to Solution.
No, You can only add edges or sketch geometry.
In this case, you can create an auxiliary 2D sketch, project into it the necessary axes and then add them to the 3D sketch.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
