Include Geometry (Work Points) in Tube & Pipe runs. IV2020
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Morning, everyone.
Due to the hardware changes (new valves had to be put in place) I need to reconnect the existing routes to the new valves.
But it seems - project geometry in pipe route is limited to selecting faces only. While I do have work points I want to use in the valve itself - they are not selectable for projection in T&P run. The valve is authored for Pipe components,
To deal with the issue - I an creating a work point on the assembly level instead. That point can be projected. But why not the existing point from the valve itself? Yet the Help File states that work geometry can be projected too. It just doesn't say - work geometry from which level? is it from the assembly one or from the part? What do I miss?
Thanks for your help!
Cheers,
Igor.
