Imprint part into solid?
Message 1 of 13
could somebody help me with this problem please?
I have a plastic part and I need negative shape of it imprinted into solid. Something like if you push that part few centimeters into block of clay or something.I want to create some fixture in which can this part fits and sits. For Inventor mold creating environment is this part too complex.
What is the easiest way to accomplis that?
Thank you.
Replies (12)
Message 2 of 13
mcgyvr
derive
http://www.widom-assoc.com/derived_parts2.pdf
Message 3 of 13
Cadmanto
Take a look at the core/cavity portion from the help file.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 13
I tried this but my part has open top and thin walls, so with this method, inside of my part was filled with that blank. What did I wrong?
Thank you.
Message 5 of 13
I tried this as well but my part is more like assembly = to complex for this (combining bodies doesn't help). Core/Cavity design is pretty strict and I have problem to create Runoff surface.
Thankx anyway.
Message 6 of 13
Cadmanto
Have you tried doing an assembly cut using the cavity components as the cut edges?
Best Regards,
Scott McFadden
Message 7 of 13
Can you elaborate, please? I am not sure what do you mean.
Thank you.
Message 8 of 13
CCarreiras
Hi dont you just post the part here and let us find the core nd cavity?
CCarreiras
Message 9 of 13
I have a few different parts I would like to resolve, so doing it for me doesn't help in a long run... if you know what I mean.
But thank you.
Message 10 of 13
dan_inv09
If there are no holes or gaps in the part you "push in" the "fill" should be easy to get rid of with the "Select Lump or Void"option of "Delete Face" (usually tucked under the modify section of the 3D Model tab).
Message 11 of 13
salariua
Why don't you use combine on the 3D Model tab, Modify panel? Create a new block enveloping your part then use combine to subtract your body out of the block. Additionally use split to get separate bodies for upper/lower mould parts.
Attach the part here if you can't do it.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 12 of 13
JDMather
@mike wrote:
I have a few different parts I would like to resolve, so doing it for me doesn't help in a long run... if you know what I mean..
No, I don't know what you mean.
I would make the opposite argument.
Inventor is a history-based tool, so by studying how one problem was solved - I can learn to solve many similar problems.
That is exactly how I learned Inventor.
In fact, I have often seen different users post 5 or 6 solutions here, each one building on the previous solution - eventually arriving at very elegant solutions using techniques that I might not have thought of.
The internet serves as a collaboration laboratory.  A "collaboratory" if you will.  Crowd sourcing of experience and brain-power that is greater than any individual capability.
Message 13 of 13
CCarreiras
But thank you.
So, how we supposed to help you, if we don't see what's the problem for your specific case? Do you think we are some kind od wizards that guess what's your problem without see it?.......
Posting the part, you say that you will not learning something....
.......and until now? have you learned something? i'm not a wizard, but i guess not ... 🙂 .... good luck...
CCarreiras
