Good afternoon. I have been trying to create a wing in inventor by lofting different airfoils together. To create each airfoil i import some coordinates from excel and join the points with lines. The shape looks good but the problem arises when lofting. When I loft two airfoils together, some lines appear on top of the surface connecting dots between different airfoils together. Is there a way to prevent this from happening (just lofting outer surface without lines appearing? Thank you very much.
Solved by admaiora. Go to Solution.
Can you attach the file?
Admaiora
My advice use spilne for your loops, not lines.
Admaiora
Thank you very much. I already tried using spline. However, when I use it, for some reason it doesn’t allow me to extrude it as it tells me it is an open loop and that there is a redundant point. I already mentioned this issue in a previous post which is at the top of the unread posts as of now.
Can you attach the excel file for just only 2 profiles?
Admaiora
Admaiora
That was really useful. Thank you very much. One last question, if I wanted to make the loft a particular thickness and make the insides hollow, what tool or option should I use?
