importing excel points to inventor
Message 1 of 9
Good afternoon. I have been trying to create a wing in inventor by lofting different airfoils together. To create each airfoil i import some coordinates from excel and join the points with lines. The shape looks good but the problem arises when lofting. When I loft two airfoils together, some lines appear on top of the surface connecting dots between different airfoils together. Is there a way to prevent this from happening (just lofting outer surface without lines appearing? Thank you very much.
Replies (8)
Message 2 of 9
admaiora
Can you attach the file?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 9
here is the file
Message 4 of 9
admaiora
My advice use spilne for your loops, not lines.
Admaiora
Message 5 of 9
Thank you very much. I already tried using spline. However, when I use it, for some reason it doesn’t allow me to extrude it as it tells me it is an open loop and that there is a redundant point. I already mentioned this issue in a previous post which is at the top of the unread posts as of now.
Message 6 of 9
admaiora
Can you attach the excel file for just only 2 profiles?
Admaiora
Message 7 of 9
here are the two excel files
Message 8 of 9
admaiora
Admaiora
Message 9 of 9
That was really useful. Thank you very much. One last question, if I wanted to make the loft a particular thickness and make the insides hollow, what tool or option should I use?
