Imported files from previous version become transparent
wagari.aboma68FYZ
wagari.aboma68FYZ
When I import my files from a previous version of inventor (2020) to a new version (2023) their appearance is transparent wether it is a part or an assembly. How should I fix the problem?
CCarreiras
HI!
What do you mean by IMPORT?
Can you share a part as an example?
CCarreiras
Gabriel_Watson
Right-click the part/assembly/component in the Model browser and see if those are "Enabled" and NOT set to "Transparent".
Another possibility is if your models use any bitmap appearance that has a "&" in the file name (of the bmp):
https://forums.autodesk.com/t5/inventor-forum/appearance-became-transparent/m-p/6374903/highlight/tr...
johnsonshiue
Hi! Maybe the file was exported as a surface or imported as such. Please share the file here. It is hard to tell by the image.
Many thanks!
Software Test Engineer
