Area iproperty on drawings showing units as m^s instead of m²
johnster100
johnster100
when I use the area iproperty in my drawing the units get displayed as m^2.
How do I get them to display as m²?
thanks,
John
thanks,
John
CCarreiras
HI!
There's no way to do that... it's a system configuration.
CCarreiras
johnster100
thanks for the reply.
I'm guessing there is no way to show it without units?
(that way I could add the units myself).
thanks again,
John
CCarreiras
 guessing wrong😁...
...you can format some things in the parameter output...one of them is the unit's visibility:
CCarreiras
johnster100
yes but unfortunately this is not a parameter. It's from the physical properties section in the iproperties dropdown area 😞
A.Acheson
You could do this with ilogic by reading the property, stripping the units and adding in the correct units but not an easy way to display what should be the standard unit string. It will also be open to human error if units change etc. Here is hoping to some of these niceties being implemented and backdated to earlier releases.
Regards
Alan
CCarreiras
Well.... is possible to create a parameter based on the "Area value"
Run an iLogic Rule:
Area = iProperties.Area
Then you format it and use it as you wish.
But.... at the end.... i wouldn't touch on this.... m^2 is a standard unit, as you can see also in other programs like excel, etc.... just keep it like that and save time...
CCarreiras
