Inventor Forum
import dwg
2 REPLIES 2
311 Views, 2 Replies
import dwg
Hi guys,
I need some help.
I'm trying to import a .dwg file from autocad 2008 to inventor 2014, but when i do this my metric changes from mm to inches.
how can I solve this, leaving my original mm to mm?
thanks a lot
2 REPLIES 2
mdavis22569
Welcome to the forum ....
when you click import ... and does the import box come up, and if so did you go through all the pages ..till
here you can pick your Import File units ...
Mike Davis
JDMather
Can you attach the original dwg file here?
If you run the -dwgunits command in AutoCAD - what does the command line report?
Technology Administrators
