Hi guys,
I need some help.
I'm trying to import a .dwg file from autocad 2008 to inventor 2014, but when i do this my metric changes from mm to inches.
how can I solve this, leaving my original mm to mm?
thanks a lot
Solved by JDMather. Go to Solution.
Solved by mdavis22569. Go to Solution.
Welcome to the forum ....
when you click import ... and does the import box come up, and if so did you go through all the pages ..till
here you can pick your Import File units ...
Can you attach the original dwg file here?
If you run the -dwgunits command in AutoCAD - what does the command line report?
