Inventor Forum
Image does not get rendered? Inventor Studio.
9 REPLIES 9
Message 1 of 10
jgjYRRKE
1395 Views, 9 Replies
Hi all.
How come this green/orange text on my hose does not get rendered?
It renderes as full black instead.
I use the .PNG file below.
9 REPLIES 9
Message 2 of 10
mcgyvr
in reply to: jgjYRRKE
What version of Inventor?
Is that done using the tube/pipe module or cable/harness?
Just a sweep? Surface or solid?
Its working for me in 2020 on just a regular extrusion..
Message 3 of 10
jgjYRRKE
in reply to: mcgyvr
Inventor 2020 and the hose is made using Tube&pipe 🙂
For me it does not even work on an extruded part.
Just renders black using generic apperence.
Message 4 of 10
jgjYRRKE
Message 5 of 10
mcgyvr
Try the attached part..
Message 6 of 10
jgjYRRKE
in reply to: mcgyvr
That works fine, but adding the material from your part to favorites and using it on the original hose does not work.
What am i missing?
Message 7 of 10
jgjYRRKE
in reply to: mcgyvr
I have placed your part in assembly and it does actually render, but only at the ends of the part.
Weird bug maybe?
Message 8 of 10
jgjYRRKE
So, it turns out to be a position/scale thing.
After playing around with the scale and position settings it worked.
I did have to change the texture to avoid the transparent parts showing as heavy black.
Adding background with noise in photoshop helped.
Thank you for your time mcgyvr.
Message 9 of 10
Khanh-Nam
 What does 2/18 on the tube mean?
Message 10 of 10
jgjYRRKE
in reply to: Khanh-Nam
I am not sure?
Maybe the manufacturer know?
They should 🙂
