Exporting threads to STEP
RichStow
RichStow
I am using Inventor 2025. I am creating parts to be 3-D printed. Some of these parts have external and internal threads (e.g. bolts and nuts). When I export the files to STEP, the threads disappear, and I am left with smooth shafts and holes. I have printed objects with threads that I have downloaded from other libraries that work just fine. Is there a procedure or command that will work in Inventor 2025 to export these threads?
SBix26
Threads in Inventor are data-only, with cosmetic texture added for visualization.  For 3D printing and export, you will need to cut actual threads.  There are tutorials on YouTube and lots of advice in this forum.  One very interesting topic: Solved: best way to add threads for printing purposes? - Autodesk Community - Inventor
Sam B
Inventor Pro 2025 | Windows 11 Home 23H2
chris
@RichStow you can add Cool Orange thread Modeler to Inventor which allows you to cut geometric threads, which will export with .stp, (this is my "daily" workflow). If you want to add Cool Orange to your 2025, there are a couple of steps you need to follow, you can check out this thread: https://forums.autodesk.com/t5/inventor-forum/cool-orange-thread-modeler-in-iv2023-2024-and-2025/td-...
Here are a couple of videos to check out:
RichStow
Thank you. This worked perfectly.
RichStow
Thank You. This information was most helpful.
andyasskwoo
Community Visitor
Community Visitor
You can include them by selecting "Modelled" in the threads tool.
JDMather
@RichStow
You are in the wrong forum - that is Autodesk Fusion.
