Cool Orange Thread Modeler in IV2023, 2024 and 2025
chris
Advisor Advisor
Message 1 of 20
chris
So for anyone interested, I have the Cool Orange "Thread Modeler" add-on running in Inventor: 2023, 2024, and 2025, in my opinion, it produces better and more geo-accurate threads than Fusion 360 does.
I don't know why Autodesk doesn't just make this work natively...?
Replies (19)
Message 2 of 20
ethan_howardMMXXV
How are you able to make it work?
Autodesk Inventor Professional 2024
64-Bit Edition
Build 272, 2024.2.1 Update - Date: Thu 2/8/2024
Autodesk Vault Professional 2024
Build 29.2.88.0
2024.2.1 Update
Message 3 of 20
Alexander_Chernikov
Here is the instruction
https://www.youtube.com/watch?v=br8fUCDt8Vw
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 4 of 20
ethan_howardMMXXV
Awesome! Thank you.
Message 5 of 20
ethan_howardMMXXV
@chris I remember seeing recently that Autodesk has taken an integrated thread modeler idea under advisement. I'm sure @johnsonshiue can put his finger on it for us.
Message 6 of 20
chris
@ethan_howardMMXXV  watch the video that @Alexander_Chernikov  shared, the plugin needs to be in whatever version of Inventor you are using, addon location (example):
the number you are changing it to for:
2023: 27 or 28 (I think)
2024: 29
2025: 31
Message 7 of 20
ethan_howardMMXXV
I can see why Autodesk is not too thrilled to jump on the Orange thread modeler bandwagon. It doesn't play well with features like c'sinks and cast surfaces. It would work well with flat plates and c'bores though. I could probably get it to work but would require additional features so it's not worth it to me.
Message 8 of 20
chris
@ethan_howardMMXXV Once you run the thread modeler you have to "combine" the solids, otherwise, any cutting, chamfering, etc is only on the first solid, (unless you choose both)
Message 9 of 20
chris
We use the Thread Modeler for our render threads and section views and it works great for us. We do not use it for production work or finished drawings. (Apologies, I couldn't find the high res image for the yellow gun handle cut-away)
Message 10 of 20
Rich-T
Place your suggestions here...
Real Thread Modeled - Page 5 - Autodesk Community
Message 11 of 20
reggie.harrison
We are new to using Cool Orange Thread Modeler. How did you cut the slot through the threads. I can't cut through at all.
Message 12 of 20
k.hendrickx
After creating the thread, combine the new body the threadmodeler made with your original body. Then create a sketch for a slotted hole and extrude cut.
On topic, while the threadmodeler plugin works in 99% of the cases, it does create problems in regards to annotation in drawings.
Message 13 of 20
lancermandc_co_za
How are you able to use it in Inventor 2023 and upwards if Thread Modeler is not compatible with those Inventor versions??
Message 14 of 20
k.hendrickx
You just have to make a very small modification in a config file.
There is a YouTube video of it. Can make it work in any version of Inventor.
Message 15 of 20
justinthursday
Hi all,
I just wanted to jump in and say that the Youtube video is out dated. But they're just following this page which is updated and works:
https://www.cadforum.cz/en/true-3d-models-of-threads-in-inventor-2022-and-2021-tip12962
Message 16 of 20
jtcom
why is cool orange thread modeler not producing correct major / minor dia for 1/4 - 20 thread
Message 17 of 20
paolo_gutierrezGYQVN
Observer
Observer
How to fix??
Message 18 of 20
WillL84
Yea finally after YEARS of requests on the ideas forum.
Windows 11 Pro 64-bit
Inventor 2025 (PDMC)
TITAN Computers C161
i7-11700K/32GB RAM/Quadro RTX A4000
Message 19 of 20
jtcom
finally what?
Message 20 of 20
WillL84
Click on the name after "in reply to" and it'll show the post I was replying to
