iLogic Rule to change solid body visibility
marcin_bargiel
marcin_bargiel
I need iLogic Rule to change solid body visibility in IPT file. I DO NOT want to use "Feature.IsActive("featurename") but just VISIBILITY as i can by hand.
Vote for REPLACE VARIES !
REPLACE VARIES
Thomas_Savage
You con use:
Component.Visible(" ")
In iLogic, expand the components tab, and you will see Visible.
Which will change the visibility of your component.
Hope this helps?
Thomas.
Thomas Savage
Design Engineer
ThomasB44
Hi @marcin_bargiel
This rule by @Curtis_Waguespack do this perfectly.
http://inventortrenches.blogspot.fr/2013/01/ilogic-solid-body-visibility.html
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
marcin_bargiel
Components are in iam file ! So You didn't help...
I was talking about features in ipt file.
We can change visibility by 'hand' (click on one of chosen feature -multibody) but how to do this by ilogic rule ?????
REPLACE VARIES
marcin_bargiel
My rule, that works OK 😉
Sub Main()
VIS("feature name", False)  'visibility OFF
VIS("feature name", True)   'visibility ON
End Sub
Function VIS (FeatureName As String, Visibility As Boolean )
Dim oCompDef as ComponentDefinition
oCompDef = ThisDoc.Document.ComponentDefinition
Dim oBody As SurfaceBody
j=1
i=1
k=178  'number of features
For i=1 To k
    oBody = oCompDef.SurfaceBodies.Item(i)
    If oBody.Name= FeatureName Then
        j=i
        i=k
Next
oBody.Visible=Visibility
End Function
REPLACE VARIES
marcin_bargiel
Solution above works - but when we have a large number of features it works slowly.
Is there any other way to change visibility ? without need to know exact item number (and need to use loop "for" or "while")
something like this oCompDef.SurfaceBodies.Item("features name")= False
REPLACE VARIES
jeamy.baena
Hi, @marcin_bargiel
In my case, your code worked like a charm!!! 👏. This is all that I needed 😀
Thank very much!!!
