Is there a line of code that will look at a drawing view and turn shading on?
I have tried
ActiveSheet.View("VIEW1").View.Shaded = True
but it didn't work
Solved by VdVeek. Go to Solution.
There was an older post here: http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-code-for-Visual-styles-Shaded-w...
Hope that helps you.
Rob.
Thanks but the post seems to be refering to the Display Style in the modelling environment, whereas I want to change the style of a drawing view.
This is from VBA, experiment with it to make it work in iLogic.
DrawingView.ViewStyle = kShadedDrawingViewStyle
I'm not sure how familiar you are with coding in iLogic, but post back if you need more help.
This iLogic code works for a drawing and changes all views in the selected sheet.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' select drawing views on active sheet
Dim oDrawView As DrawingView
For Each oDrawView In oSheet.DrawingViews
'adjust drawing view style
oDrawView.ViewStyle = DrawingViewStyleEnum.kShadedHiddenLineDrawingViewStyle
'OPTIONS TO CHOOSE FROM
' kHiddenLineDrawingViewStyle = 32257
' kHiddenLineRemovedDrawingViewStyle = 32258
' kShadedDrawingViewStyle = 32259
' kShadedHiddenLineDrawingViewStyle = 32261
' kFromBaseDrawingViewStyle = 32260
Next
Thanks Mike,
I have been having a play around but haven't had any luck yet. i though the following may work but Inventor can not recognise 'View Style':
ActiveSheet.View("VIEW1").ViewStyle=kshadedDrawingViewStyle
I get the folliwng error:
Rule Compile Errors in Rule0, in 09090G00105414.idw
Error on Line 1 : 'ViewStyle' is not a member of 'Autodesk.iLogic.Interfaces.ICadDrawingView'.
Thanks VdVeek
@Alexrose1942, for a multisheet drawing the code will be:
Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet 'oSheet = oDrawDoc.ActiveSheet For Each oSheet In oDrawDoc.Sheets ' select drawing views on active sheet Dim oDrawView As DrawingView For Each oDrawView In oSheet.DrawingViews 'adjust drawing view style oDrawView.ViewStyle = DrawingViewStyleEnum.kShadedHiddenLineDrawingViewStyle 'OPTIONS TO CHOOSE FROM ' kHiddenLineDrawingViewStyle = 32257 ' kHiddenLineRemovedDrawingViewStyle = 32258 ' kShadedDrawingViewStyle = 32259 ' kShadedHiddenLineDrawingViewStyle = 32261 ' kFromBaseDrawingViewStyle = 32260 Next Next
