iLogic: inputbox cancel
Message 1 of 13
I'm trying to create a user input, by using the inputbox. But I also want to be able to cancel the operation. I tried writing it like this but no succes! What do i need to change in order to work?
This rule cancels always.
uInput = InputBox("Default entry", "Title", sPrefix)
If vbCancel Then
	MsgBox("cancel")
	Return
'*** Rest of the rule***'
Replies (12)
Message 2 of 13
I also tried it like it works for messagebox:
Q = MessageBox.Show("Question", "Error",MessageBoxButtons.YesNo,MessageBoxIcon.Warning) If Q = vbYes Then 'Action ElseIf Q = vbNo Then Return End If
Inputbox code:
Q = InputBox("Question", "Title", "Default entry")
'Cancel test
If Q = vbCancel Then
	MsgBox("Cancel")
	Return
But for my inputbox i get this error:
Error in rule: MINI_MASTER_CREATE_DERIVED_PART, in document: Part2
Conversion from string "" to type 'Double' is not valid.
Message 3 of 13
andrewiv
I believe this is what you're looking for
'Cancel test
If Q = "" Then
MsgBox("Cancel")
Return
Andrew In’t Veld
Designer / CAD Administrator
Message 4 of 13
MechMachineMan
If the cancel method doesnt work for you, check this link out:
https://msdn.microsoft.com/en-us/library/6z0ak68w(v=vs.90).aspx
This just explains that if the user clicks cancel, a zero length string is returned; ie
If uInput = ""
'The inputbox was cancelled
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 5 of 13
DanSingleton
Sorry... old threads are old but this is the one Google popped up when I was searching to InputBox iLogic Handle Cancel
As I read this, there's no way to distinguish between a "vbCancel" and the user deleting all text in the dialog and clicking OK?
The reason I ask is because in the case of a "true cancel", I'd want to keep the existing value or use the default value but in the case of a user-specified empty string I would want to use that to set the value to an empty string. I guess that's not possible?
Guess I'll have to write code to check for the empty string/cancel and then "double-check" the user really wanted to use that before applying the empty string. O_o
Message 6 of 13
MechMachineMan
Just add text to let your user know that if they proceed with "0" or some other arbitrary string typed into the input box, it will make reset it to a blank string.
ie; add an else if clause to your box for the case you want the field to be empty.
r = InputBox("Choose: Type '0' to reset to blank field")
If r = "0"
    value = ""
else if r = ""
    Exit Sub
else
    value = r
End if
Justin K
Message 7 of 13
RoyWickrama_RWEI
It is strange that "CENCEL" button does not respond.
'To FIX Eng. Approved Date
oEngApprovedDate = iProperties.Value(oModelDoc, "Status", "Eng. Approved Date")
iProperties.Value("Status", "Eng. Approved Date") = oEngApprovedDate
oEngApprovedDate = InputBox("ENG. APPROVED DATE: ", "Eng. Approved Date", (oEngApprovedDate))
iProperties.Value(oModelDoc, "Status", "Eng. Approved Date") = oEngApprovedDate
I tried several options in vain.
So, decided to seek help from the forum.
Could someone help me. Thanks.
Message 8 of 13
Curtis_Waguespack
Hi rwickrama,
This should work.
I hope this helps.
Curtis
If oEngApprovedDate = "" Then
	Return 'exit rule
Message 9 of 13
RoyWickrama_RWEI
Thanks Curtis.
This cancel button is a problem always. In case I hit "CANCEL" the following code doesn't go through.
Dim oDrawing As DrawingDocument
oDrawing = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim i As Integer
xNOS = oDrawing.Sheets.Count
Err.Number = 0
100:
'myparam = InputBox("Prompt", "Title", "Default Entry")
'catch an empty string in the imput
i = 1
i = InputBox("Prompt", "Title", i)
MessageBox.Show("Message, i = " & i, "Title")
If i = 0 Then Goto 100:
oDrawing.Sheets.Item(i).Activate
I request help.
Thanks.
Message 10 of 13
ThomasB44
As Curtis said in his example code, when you hit cancel in an input box, the returned value is "" even if you have wrote something.
Not "0".
So your code should be, for example :
SyntaxEditor Code Snippet
Dim oSheet As Sheet
Dim i As Integer
Dim ASheet As String
100:
ASheet = 1
ASheet = InputBox("Prompt", "Title", ASheet)
If ASheet = "" Then Goto 100:
Try
'Convert ASheet string to i number
i = CDblAny(ASheet)
Catch
'Sheet number doesn't exists
'Or wrong user entry
MessageBox.Show("Error", "Title")
End Try
Hope it helps.
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
Message 11 of 13
Curtis_Waguespack
Hi rwickrama,
Here's another variation:
Dim oSheet As Sheet
Dim i As Integer
100:
i = 1
Try
Catch
    Goto 100:
End Try
I hope this helps.
Curtis
Message 12 of 13
ThomasB44
Hi @Curtis_Waguespack
Nice tip with your Try/Catch command and the input box cancel button Smiley Wink
It works even if you enter a string value...I haven't think about that, good to know !
My code was too complicated ! Smiley Embarassed
Thomas
Message 13 of 13
RoyWickrama_RWEI
Thanks a lot. neat, tiny and perfect.
