iLogic Input List Box prompt
I'm making a rule to set a parameter using an input list box selection, using a code sample in the iLogic editor.  The "prompt" that is shown at the bottom of the message box (see attachment) really serves no purpose and I'd like to remove it, but cannot find a way to do this.  Is it possible to do this without using a separate dialog box?
mdavis22569
Can you attach  or paste the code for us to see ....
Mike
Mike Davis
It's below.  "State_List" is a multi-value parameter.
State_List = InputListBox("Select State", MultiValue.List("State_List"), State_List, Title := "Ticket State", ListName := "Select a State")
iProperties.Value("Custom", "NOTE") = State_List
iLogicVb.UpdateWhenDone = True
Koekepeerke
Hey James,
I was justing thinking about the same thing. I really don't need the prompt section for my inputlist.
Did you by any chance find a way to remove it?
regards,
Jeremy
pcrawley
You can remove the prompt by removing the text between the red quotes:
State_List = InputListBox("", MultiValue.List("State_List"), State_List, Title := "Ticket State", ListName := "Select a State")
It doesn't remove the entry at the bottom of the InputListBox, only the text.
Alternatively you could make an iLogic Form that shows the options - that way you can design the form exactly the way you want it:
And the iLogic behind it is still the same, but you drop the InputListBox:
Peter
