Design Jet 500 problems (VBA printing, ISO sizes)
I have been playing with a VBA code to ease the printing experince in Inventor.
(from this: http://forums.autodesk.com/t5/inventor-general-discussion/printing-a-drawing-in-the-right-size-by-de...
But when I try to send a print to my plotter, a HP Design Jet 500 HPGL2 Card, nothing happens. The document is showing from the windows printing queue but nothing comes out :-(. It dosen't even register at the plotter.
When I take the long way through the Inventor/windows printing dialog box it works, but that's kinda what I'm trying to avoid.
I think is must be a HP Design Jet Issue, but not sure, any hints??
Also it gives error when using "kPaperSizeA2", but that can be solved by using "kPaperSizeCustom".
Mark_Wigan
there will be good resources if you post in the customisation area of the forum JJ.
have you tried sending to an alternative printer... even a pdf writer will tell you likely if your routine works or not. (test it on a small batch though of course).
cheers.
ps if you do repost this in the other forum please justy make a link to it from here, and also maybe attach the code you have put together for us to look at.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
