Design Jet 500 problems (VBA printing, ISO sizes)
I have been playing with a VBA code to ease the printing experince in Inventor.
(from this: http://forums.autodesk.com/t5/inventor-general-dis​cussion/printing-a-drawing-in-the-right-size-by-d...)
But when I try to send a print to my plotter, a HP Design Jet 500 HPGL2 Card, nothing happens. The document is showing from the windows printing queue but nothing comes out :-(. It dosen't even register at the plotter.
When I take the long way through the Inventor/windows printing dialog box it works, but that's kinda what I'm trying to avoid.
I think is must be a HP Design Jet Issue, but not sure, any hints??
Also it gives error when using "kPaperSizeA2", but that can be solved by using "kPaperSizeCustom".
I have attached my code (VBA, not iLogic)
adam.nagy
Autodesk Support
Autodesk Support
Could you please try to print programmatically from another VBA enabled application, e.g. Excel?
I wonder how that behaves.
Cheers,
Adam Nagy
Autodesk Platform Services
good idea. I will try.
