iLogic Export To DXF Lines Showing
TheClenched
TheClenched
Hey guys,
I'm trying to use iLogic to export a DXF. In our business, we just want the outer exterior profile of the Flat Pattern and that's it. We don't want to show any bend lines or anything. I have labeled the variable to output as such.
Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2018" _
+ "&OuterProfileLayer=IV_EXTERIOR_PROFILES" _
+ "&InvisibleLayers=IV_TANGENT" _
+ "&InvisibleLayers=IV_BEND" _
+ "&SimplifySplines=True"
This outputs the picture that I have attached which shows the bend line. Can someone let me know what I'm doing wrong here?
Thanks!
Gabriel_Watson
TheClenched
I was able to make this work with this code. Thanks!
As a sidebar, do you know why the other code wasn't working to remove those lines or no?
Let me know.
Cheers!
Anthony
Gabriel_Watson
You're welcome!
I assume one of two thigns are happening to make this "right" for your preference:
1- the "oCommand.ControlDefinitions.Item("GeomToDXFCommand").Execute2(True)" is the key line here, and although I haven't used it myself, perhaps "Execute2" is a different way of exporting this without the bend lines;
2- or, "GeomToDXFCommand" is simply being executed on the top face only, since a previous line acquires the top face from the flat pattern, and perhaps that dulls it out to a dumb solid: "Dim oFace As Face = oFlatPattern.TopFace".
TheClenched
Ah I see.
Well at least we found a solution that works.
Cheers!
Anthony
