Arrange / tile windows and home screen
jyager
jyager
In previous versions if you tiled a couple windows you could close the home screen since there's no reason to tile a screen with the project lists and recent files.
Now in 23 you're stuck with it and have to just resize the window to a sliver? Am I missing something?
Jason Yager
Inventor Professional 2025.0.1
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
sundars
Hi @jyager
No you are not missing anything :(. The close "x" button was removed from Home window in 2023. However, you can still "Arrange" windows instead of tiling and minimize Home. That would be one workaround.
We are looking into changing the tiling behavior of Home so that it doesn't participate in tiling and not come in the way of other documents. It not a quick fix unfortunately and requires a bit of rework.
For the moment, the only way to turn off Home is to uncheck "Show Home" in Application Options and restart Inventor.
-shiva
Shiva Sundaram
Inventor Development
jyager
Well that's an odd unproductive change, but thanks for the work around.
Jason Yager
Windows 10 Pro 21H2
32GB RAM
