iLogic and Sketches
iLogic and Sketches
iLogic and Sketches
Hello ,
How can I array (Pattern) a sketch (of a part that placed into an assembly) from that assembly by iLogic?
Thank you
blandb
I'm not certain I fully understand what you are trying do to.
Autodesk Certified Professional
I have a part file contains of two sketches
The part file placed in an assembly file in order to use the sketches as
skeleton sketch for frame generator
I want to control the sketch dimensions and sketch pattern from the
assembly file by iLogic
I wanna know how to create a pattern from one of the sketches in the
assembly by iLogic
johnsonshiue
Hi! I don't think such workflow exists. Sketch geometry can be patterned. But, the sketch itself cannot be patterned. The closet thing is patterning part (containing the sketch) in assembly. Is it what you are looking for?
Many thanks!
Software Test Engineer
Thanks for the response. This is what I did so far
I have an assembly file with a placed part. The placed part is a skeleton model with just a sketch.
in the assembly file, I have a rule with the following code
When I run the rule, it is working, and the result is correct, but I faced the below error message.
blandb
Is there a reason you don't make the frame weldment, then place that into an upper level and pattern it from there?
