extruding cut between to different size rectangles
meguinness1
Message 1 of 15
meguinness1
hi guys
hope you can help, im a newbie and trying to create a new fan shroud for my 3d printer. How do i create a channel between the top and bottom apertures as they are different size and not parallel to each others?  probably i started the design in the wrong way as i cannot find a way to do it. thanx
Replies (14)
Message 2 of 15
rogmitch
One option is to create a workplane offset from the lower surface of the shroud at a distance such that an extruded cut of the lower slot to the workplane ends central to the part.  Then loft from the end of the extrude cut up to the upper slot
RM
Message 3 of 15
JDMather
Attach your file here.
Message 4 of 15
meguinness1
Thank , file attached .
Message 5 of 15
JDMather
I would do the entire part very differently - but one option is Loft. (A lot of wasted material on the right side.)
See Attached...
Message 6 of 15
meguinness1
Thanx ,i cannot open the file ...it says that my version of inventor is one year older and need to update.
Message 7 of 15
JDMather
Oops, let me create another example.
What version of Inventor did you state you are using?
Message 8 of 15
meguinness1
Inventor 2021, thanx
Message 9 of 15
JDMather
See Attached.
Message 10 of 15
meguinness1
thank you ...you are a star , now i have to lean to do it my self 😀 , youtube here i come. thanx again
Message 11 of 15
JDMather
YouTube? Nobody on YouTube knows anything about modifying in Inventor!
Message 12 of 15
meguinness1
Lol , i see you have your own channel ...maybe you can post a short video on how you modified my file , it would help me and many others  , im trying  to recreate your modification but is not going well🤣
Message 13 of 15
meguinness1
hi , can you help me out understand how  you modified my file please...cant replicate it.
thanx
Message 14 of 15
JDMather
@meguinness1
It is really difficult for me to figure out where you are going with this.
Do you have an photo of an existing part you are attempting to modify?
Message 15 of 15
meguinness1
I really appreciate your input, im trying to improve the Fan Duct of my 3d printer the one that seat next to the extruder that cools the pla while printing  by recreating what is fitted originally there  and try to then add a second duct on the opposite side . will post photo later. thanx
