HI 🙂
i using a inventor 2020 , update patch all done 🙂
The number of part file is about 2,500
i have cheked style option HIDDEN LINE.
now
export Autocad DWG (not inventor) time is 7min. 😞 😞 😞
is it normal?
Thank you for reading
Solved by johnsonshiue. Go to Solution.
Hello @Anonymous,
It sounds like a little bad, please share the drawing file to me and we can debug it.
Thanks!
thank for answer
down load link
http://qnap.u-serv.co.kr:8080/share.cgi?ssid=08pVTNW
this is autodesk sample file , The other file is the same condition
total assembly : workspace forder and name is Complete Building.iam
idw file name is workspace forder test.idw
Hello @Anonymous,
Thanks for sharing the data.
Ticket (INVGEN-34312) has been filed against, please stay tuned for more information.
Thanks!
Hi! The number of components is probably not that important in this particular workflow. It is about the amount of geometry or edges. In this case, I bet there are probably million of edges in the 3D and 2D. Do you mind if I ask what you are trying to do in the exported dwg file? If you want 3D as wire, you can simply export the Inventor iam file as AutoCAD dwg. Then you can open the dwg file in AutoCAD. Would it work better?
Many thanks!
Hi @Anonymous,
Could you please check if Johnson's suggestion works for you? I tried export the Complete Building.iam (several files missing need to be resolved). to autoCAD dwg, which takes 300s on my machine.
To investigate the idw to dwg file, could you please attach the test.idw file? I didn't find it from the link.
